  • Guests: 49
Measuring diode speed?
Sat Mar 10 2007, 12:18AM Print
Hi all. I've run into a problem with the high voltage diodes I bought a while back, and wondered if its due to inconsistencies in the speed.
Does anyone have a method for determining the reverse recovery time of diodes at 1KV+?
I have:- a 'scope, a frequency counter and the usual junk (555's,. 4047's, etc)
Ideally need to generate a graph of frequency response versus time.
Thanks, -A
thedatastream
Sun Mar 11 2007, 08:23PM
If you look in this datasheet for UF4007 Link2 it shows a basic method for measuring trr
Here's another Link2 found from a quick google for for "measure reverse recovery time"
Your problem will be generating a 1kV pulse with sufficiently fast rise time. You could always test the rectifiers at several lower voltages and attempt to extrapolate out to 1kV. If it's linear, it could make life easier.
Also, it might be worth describing your problem in more detail in case anyone has a different approach.
HTH
James
Tue Mar 13 2007, 03:09PM
Thanks for the tips :)
I bought some diodes on Ebay a while back which are supposed to be "fast" (300nS) 28KV 100mA black plastic diodes, but the output on my converter is pitiful. Even at 10KV input I am still getting a fraction of the correct output, and hardly any current.
Its possible I have a faulty diode but its strange that the "glass rectifier" stack made using
diodes from CPC worked just fine until it fried.
Maybe I should have tested the diodes first? will try this next.
-A
Dr. Shark
Thu Mar 15 2007, 10:57AM
What is your "converter", and at what frequency are you driving it?
I don't think the voltage matters much for testing, since the diodes probably drop relatively little voltage during reverse recovery. Thus you could just attach a diode with a load resistor to a square-wave generator and put your scope across it. The output of a 555 is proably a bit weak to quickly charge the junction capacitance, so using a gate driver for the output stage of the signal generator would be a good idea.
