  • Guests: 58
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
using a CRT as an X-ray tube?
Download
Mon Mar 05 2007, 07:26AM Print
Download Registered Member #561 Joined: Sat Mar 03 2007, 02:46AM
can i use a CRT as a x-ray tube? confused
and what is the x-ray protections circut in a tv? confused
robert
Mon Mar 05 2007, 01:19PM
robert Registered Member #188 Joined: Thu Feb 16 2006, 05:18PM
I wouldnt, especially since a CRT has the front made from over 3cm thick leaded glass.
That wont pass much radiation.
Myke
Mon Mar 05 2007, 02:01PM
The CRT prduces some weak x-rays but like robert said there are ~3 in of leaded glass protecting you. shure you could use a CRT as a x-ray tube but there are better options. A vacuum tube diode overvolted in reverse or a x-ray tube. smile
Mon Mar 05 2007, 04:06PM
Someone suggested using a microwave magnetron in reverse with the magnets removed.
However I am not sure if there would be dangerous levels of microwave radiation so this is probably a bad idea/./
Zum Beispiel
Mon Mar 05 2007, 04:31PM
I doubt a magnetron would produce any microwaves if you removed the magnets. Without the external magnetic field to deflect the electron flow it will probably act just like a regular diode.
I'm also quite sure it wouldnt be good for producing x-rays either. It would probably flash over internally at the voltages reguired for x-ray emissions.
I dunno. Just my 2c
Hazmatt_(The Underdog)
Mon Mar 05 2007, 06:47PM
You can't find an old TV set?
I had 6 Lighthouse diodes a long while back before I gave up the majority of my tube collection. They're really not that hard to come across. You just need a flyback, its driver, and a 1B3 or similar rectifier and you will have some x-rays. Antique Electronic Supply even has them.
Liam
Tue Mar 06 2007, 03:16AM
Liam Registered Member #113 Joined: Fri Feb 10 2006, 01:40AM
I used a 6BK4 to produce copious amounts of X-Rays using a 30KV X-Ray transformer rectified with many 1N4007 diodes. It worked a lot better than I could have hoped for. A CRT will (hopefully) get you nothing because the voltages used in normal TVs are sufficient for producing softish X-Rays which will irradiate you as you stare at it smile
Download
Tue Mar 06 2007, 08:41AM
i have NEVER found a valve tv sad
and the tv tube i have got is from a mini tv. the flyback makes tiny arcs that are about 5mm long and can draw to 12mm. i have also got a tincy wincy tv tube the glass would only be 1-2mm thick on the face of the tube
