  • Guests: 35
Use for 1000's of 9vdc 500ma wall-warts?
Mon Mar 05 2007, 06:49AM Print
GreySoul Registered Member #546 Joined: Fri Feb 23 2007, 11:43PM
So I have a storage unit full of 9vdc wall-wart style transformers, most are 500ma. I have been wondering what to use them for, and havent settled on anything yet.
They're well made, full wave rectified and filtered with a 25v 470uF cap.
I came up with a couple ideas and a few ideas have been tossed about among friends... then I saw the 100 9v battery thread and it got me to thinking about it again.
What could I do with 9000vdc at 2-3 amps? (I have thousands of these things) Is that something that could power a linac?
I dunno.... just saw that batrtery thread and I had to throw this out to you guys :)
-Doug
Download
Mon Mar 05 2007, 06:54AM
Download Registered Member #561 Joined: Sat Mar 03 2007, 02:46AM
wallwart powered jacobs ladder?
wallwart powered tesla coil?
mod edit: wallwart powered double post! please re-read board rules!
Dr. Slack
Mon Mar 05 2007, 08:12AM
Given the decreasing electrical efficiency of transformers as the size goes down, the best thing you can do with 1000s of wall-warts is to use something else if you want the power. You can't get 9000v DC out of them, the transformer insulation won't take the stacking (you can stack batteries)
you could try
a) epoxying them into a sculpture
b) selling them on eBay
c) using them as ballast for a driveway
d) give them away at your local mall
in fact anything instead of drive a 4.5kW DC load from them
Download
Mon Mar 05 2007, 08:52AM
i think overload them so they melt cheesey
Mon Mar 05 2007, 10:23AM
Connect them all in parallel to get 9V @ 500A, make a wall-wart powered barbecue, and try to get yourself Digg'd with it.
Myke
Mon Mar 05 2007, 01:49PM
I think there would be internal arcing if too many walwarts were rub on the same circuit because the differance between the first and the last would be ~9kv. I don't think those transformers were ment to see ~9kv on their insulation. Anyway... it would be really cool to have a wallwart powered RSGTC but I think you might have problems with quenching.
ShawnLG
Mon Mar 05 2007, 01:59PM
Why did you buy 1000's of 9vdc 500ma wall-warts?
Mon Mar 05 2007, 03:23PM
I didn't buy them, per se. I bought the entire storage unit.
it's full of cheap chinese video games. DDR knock offs, a combat game with a gun, boxing, soccar, ping-pong, etc.
Little modules you plug into a TV - the games are built into the controllers....
anyways in addition to that I have thousands of 9v wall warts, among boxes of other misc stuff.
I have boxes of little modules that I _THINK_ are voice modules from a talking dall type toy.
boxes of ceramic heating elements
boxes of shampoo
boxes of boxes of boxes.
If anyone needs a 9v wallwart to replace a 9v batter opperated device lemme know - all ya gotta do is pay shipping.
-Doug
Mon Mar 05 2007, 03:38PM
Hey.. I had an idea. Strip out the capacitors and rectifiers, those are useful. Then, sell the transformers on Ebay, centre tapped 9V transformers are very useful for repairing small appliances.
Also, the talking modules sound useful if they can be adapted to change their output. I have modified the "talkie cards" to fit in 1 square inch of space using a Dremel and some rewiring.
Another idea I had:- make a "degaussing plate" using say 16 of the transformers with the I pieces taken out and the T pieces flipped round so they point in the same direction.
-A
Mon Mar 05 2007, 03:53PM
Open one up, and see if the transformer is the "potted" type, since these can easily sustain 5kv potential difference between pri and sec (for total 10kv with grounded center). You can make a MMT (Multi Mini Transformer) array to drive a monster jacobs ladder or a big Tesla coil smile
A bit more realistic idea would be to run the transformers in "reverse" - series their low-voltage secondaries until they stack up to the mains voltage, you can use a few parallel "strings", then series the primaries (or again- make a series-parallel connection). This would make a nice and cool power supply for a low-powered Tesla coil smile
