  • Guests: 42
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
How small will they go?
ShawnLG
Tue Feb 27 2007, 04:10AM Print
Starting with the top row:
1. inicator lights
2. ceramic capacitors
3. resistors
4. transisors
Here they have the smallest size.
There is a limit to size and that is solder's surface tension.
1172549400 286 FT0 Smt Tech
Myke
Tue Feb 27 2007, 04:13AM
I think the limit is how big the atoms are and what travels between them(if you don't want to solder to it, and put it in a chip instead) otherwise I think it is as small as it can go using solder.
Tue Feb 27 2007, 04:26AM
As far as discrete components, pretty much it will be limited by the smallest size of a part you can solder down to a board...
But for more ICs and whatnot, I can't really say. We are already down to like 50nm across for a transistor... Think about that, that is 1/10th of the wavelength of green light suprised I suppose there has to be a point where the transistors just don't work anymore... Then we switch over to quantum computers ;)
BTW, you forgot to put a vacuum tune before the transistor ;)
ShawnLG
Tue Feb 27 2007, 07:43AM
"BTW, you forgot to put a vacuum tune before the transistor ;)"
I thought about it and it would of been a Nuvistor.
EDIT:
New chart with tube section and smaller SMT components.
1172642128 286 FT1630 Smt Tech2
