  • Guests: 44
Forever flasher
Myke
Thu Feb 22 2007, 09:42PM Print
Does anyone know where to get a 4016?
Thu Feb 22 2007, 10:00PM
Yes, you do, you just don't realise it yet. Use the force.
Tom540
Thu Feb 22 2007, 11:25PM
Tom540 Banned on 3/17/2009.
The question should be. Where can you not get one?
ShawnLG
Fri Feb 23 2007, 01:13AM
Don't be tempted to use the 4066. They leak a lot of current and will not work with the forever flasher. Good luck.
Myke
Fri Feb 23 2007, 06:16AM
I just wanted to know where to get the HEF4016BP. Also would any high brightness LED work?
benbradley
Fri Feb 23 2007, 05:34PM
benbradley Registered Member #312 Joined: Mon Mar 13 2006, 01:50AM
I was about to suggest a surplus supplier, but it looks like they're still made and available from new suppliers. There's one on this page:
CD4016BE 296-2036-5-ND Quad Bilateral Switch ....................................14-Dip .48 .36 .27
I presume you want DIP instead of SOIC, but SOIC is also available.
48 cents each is cheap enough, though of course Digikey has their minimum order amount: "A $5.00 handling charge applies to all orders less than $25.00."
I haven't read every post or project here, where's a forever flasher schematic? When I was a kid there were no LED's, and long-term flashers used high-voltage batteries and neon lamps. It's the leftmost circuit here:
Myke
Fri Feb 23 2007, 06:01PM
Here is the thred from the old site Link2
EDIT on 12/30/10...: Link2
Sun Feb 25 2007, 05:59PM
Hi..
Has anyone considered putting a series resistor in the ground line on the 4066 as a way to reduce the current drawn?
-A
Myke
Sun Feb 25 2007, 11:32PM
Here is a picture of my forever flasher minus the 4016 and LED. (it may look like there is a short but there isn't)
1172446342 540 FT21041 Img 1922
