  • Guests: 22
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Ambient Energy LED lighting contest!
1 2 3 4  last
Mon Feb 12 2007, 11:32AM Print
Hi all,
I noticed that CM recently managed to light an LED with his atmospheric electricity collector. And, I seem to remember that other board members have played with similar devices in the past.
So, your mission should you choose to accept it, is to light an LED using "Free" energy. By that I mean renewable energy, or energy that would otherwise have gone to waste such as ambient RF or EMI from your electronic toys.
For the neatest, cheapest, most powerful, and generally most clever energy harvesting device, I offer the prize of a 1 watt Luxeon (white) with optic.
Marko
Mon Feb 12 2007, 12:28PM
Hi Steve
Sounds fun, except I'm not sure if anything will beat solar cells... maybe in price if someone has luck, but in power density, hardly. rolleyes
Also, wouldn't it be a bit unfair if someone happens to have a GSM network transmitting antenna or 440kV power lines passing near his window, or something of that sort?
ragnar
Mon Feb 12 2007, 01:06PM
**digs out AM radio coils**
Mon Feb 12 2007, 01:35PM
Firkragg, we'll put it to the vote, and if anyone has 440kV power lines going past their house, they just have to be honest and own up to it. mistrust Solar cells are a good solution, but they lose on geek points by being too easy.
ShawnLG
Mon Feb 12 2007, 02:29PM
"I offer the prize of a 1 watt Luxeon (white) with optic." Ooooo. I always wanted one of them. Im in!
Dr. Shark
Mon Feb 12 2007, 03:44PM
I am also in, not so much for the LED (well, a 5W luxeon would be interesting, but 1 puny Watt?) but for the challenge.
Solar cells are out for me (I live in Finnland, remember?), so I am currently favoring some type of mechanical device coupled to a small alternator. Wind power might be a good option, since there is a lot of it flowing around, and some cute designs already exist Link2 which could be adapted.
For additional geekyness and indoor use I am also pondering some kind of LTD Stirling engine - temperature differentials exist almost everywhere, and a proper engine is a lot more fun than a simple Peltier-based thermoelectric generator.
stop4stuff
Mon Feb 12 2007, 04:05PM
stop4stuff Registered Member #64 Joined: Thu Feb 09 2006, 06:25AM
Here's one I made earlier - A weight driven generator using Lego
Write up - Link2
discussion - Link2
& video - Link2
Powers a 3mm 15,000mcd white LED for approx 6.5 mins on one drop of the weight...
cheap...mmm... Lego can get expensive
powerful... not really... mW
'free' energy... sort of, depends if one can lift 0.5kg
but it is a "most clever energy harvesting device" (imho) cheesey
CM
Mon Feb 12 2007, 04:29PM
CM Banned on April 7, 2007
Registered Member #277 Joined: Fri Mar 03 2006, 10:15AM
Steve:
Good contest, except you should up the challenge to see who can produce the most hydrogen over a one month period, something useful, AND the production technique should have NO geographic limitations AND factor in the maintainence costs of each approach. That is if you are interested in useful data. I'll look forward to seeing how much can be produced. You can be assured that everyone here knows that when the sun is shining and if you live in the right places PV is great (but the concensus is that PV efficency deminishes with time and most agree they must be replaced after about 30 years constituting a perpetual investment cycle, factor that into your contest too), or that when the wind is blowing and if you live in the right places, windmills are great, if you don't mind substancial reoccuring maintainence costs (I've built many windmills, including one with 16 foot blades, lots of maintanence costs involved over time, for the big ones anyway). Make your contest like the above and you'll end up with something useful other than just an LED lighting contest. Think about it. CM
Dr. Shark
Mon Feb 12 2007, 05:13PM
Hey Paul, I absolutely dig your weight lifting generator! IT kind of reminds me of those old clocks, where you had to pull up a weight once a day. Too bad you allready completed it before the competition started, so you cannot enter tongue
CM,I definitely appreciate your proposal to make this contest more "useful", but I think producing hydrogen is a bit overkill. It's not really related to _producing_ energy, but rather _storing_ energy, and that does not relate to the "renewability" of the energy but just complicates things. I definitely agree on the geographical issue though, and I also think that factoring in reliablity and ruggedness in addition to geekiness and neatness.
Avalanche
Mon Feb 12 2007, 06:43PM
This thread has caused my head to start overflowing with ways to light an LED cheesey most of which I'll probably never get around to trying...
A rectenna on a towerblock roof near the microwave gear might work, or as for the solar cells being too 'easy' - home-made cells might add a bit more 1337ness to the solar approach smile
What about a microphone array.....in a Wetherspoons pub... (brainiac pub science time!)
I'll have a go at this (probably at work tomorrow) if I can think up anything strange enough! A few months ago we were looking at battery-less solutions for things like room sensors, which harvest energy from the environment in various ways, usually charging a supercap Link2 We might even have some samples somewhere.
1 2 3 4  last
