  • Guests: 34
FLAME DEFLECTED by Permanent Magnet - REASON FOUND BY TOKYO SCIENTISTS
CM
Fri Feb 09 2007, 11:53PM Print
CM Banned on April 7, 2007
Registered Member #277 Joined: Fri Mar 03 2006, 10:15AM
I've been experimenting with high power neo-magnets and diamagnetic materials and liquids. I was surprised to discover that when I placed a strong neo-mag next to a candle flame, the flame behaves as it were diamagnetic, ie: the flame deflects away from the neo-mag regardless of which pole is presented. Other non-magnetic materials produced no deflection. I've goggled with little luck trying to find more info about why the flame behaves this way in the presence of strong magnetic field. Any speculations? CM
Electroholic
Sat Feb 10 2007, 12:02AM
flame is just HOT HOT HOT water and co2.
TheMerovingian
Sat Feb 10 2007, 12:21AM
Hmm, maybe the black carbon particulate is repelled itself. Or being the flame composed by conductive gases moving upwards, some faraday current is induced causing repulsion? I've to try it
Tesladownunder
Sat Feb 10 2007, 04:48AM
The neo magnet is cold and the air just next to it is cold and slow and moving down. Hot air flowing up bends away.
A little similar to the arc-repellant screwdriver I posted here a few years ago as a prank.
Peter
Eric
Sat Feb 10 2007, 05:25AM
Eric Registered Member #69 Joined: Thu Feb 09 2006, 07:42AM
If the candle flame is conductive (and I think it is since it's partly ionized/plasmafied) then it would repel from a magnetic field. It is flowing upwards fairly rapidly so this movement would generate eddy currents and repelling fields.
Chris
Sat Feb 10 2007, 05:41AM
Chris Registered Member #8 Joined: Thu Feb 02 2006, 04:34AM
Maybe it's because of diamagnetic graphite particles in the flame. Also remember neodymium magnets are easily demagnetized by heat. Samarium cobalt would be more suitable for such experimenting, you wouldn't want to hurt them.
Tesladownunder
Sat Feb 10 2007, 11:29AM
Put a non magnetised metal bar next to the flame and it should do the same. I beleive it is a simple thermal effect as outlined above. Or use an electrmagnet switched on and off.
While magnetofluid dynamics would potentially give a the observed effect with a magnet, the effect should be absolutely tiny.
Peter
Bored Chemist
Sat Feb 10 2007, 03:08PM
Just to throw another idea into the mix, a flame has a low oxygen content compared to the air round it. Oxygen is very paramagnetic so removing it would leave a relatively diamagnetic material.
Having said that, I just tried with a meths burner and a couple of disk drive magnets and I didn't see any effect.
CM
Sat Feb 10 2007, 03:47PM
Just tested it again positioning various materials close to the candle flame, including a cold non-magnatized galvinized hammer, etc. The candle flame repulsion effect seems to manifest only when I use the ultra-strong large neo-mags. CM
Sat Feb 10 2007, 04:06PM
I tried with a neo magnet and a piece of aluminium. The flame seemed to shrink away from both about equally. I think it's due to cooling or disturbance of the air flow, rather than magnetism.
