  • Guests: 36
Recycling power supply cases
TheMerovingian
Tue Jan 30 2007, 03:17PM Print
Power supply cases are made up of steel shets, so if I flat them and cut them apart with the dremel they can be used to build, for expample the casing for the coilgun pistol. Maybe using both plastic and metal would be cool, connecting the pieces with screws. The problem is to drill the holes. Normal drills with melt apart when trying to pierce steel, so i should use specific tools. Anyway , anyone tried this in past?
Madgyver
Tue Jan 30 2007, 03:22PM
You mean tools for steel?
Well you can get special drill bits with hardened tips. That should do the trick. Although those casing are made out of pretty soft steel.
Tue Jan 30 2007, 05:43PM
Some are easier to drill than others, but I've never had any real problems with them. With some brushing and polishing they can look pretty good. Heres what I use for my stereo system, its unpolished, just brushed. Link2
Marko
Tue Jan 30 2007, 06:49PM
I don't like that kind of steel, primarily because it is prone to corrosion and paint is easily scratched. When it is bent the layer of protective paint cracks and makes it corrode again.
Also, cutting and polising edges is problematic.
I didn't find it a big problem to drill with normal drills.
I did, although, see some better ATX boxes made out of stainless steel and unpainted; but I would simply prefer to find a piece of stainless laying around somewhere.
For such facy stuff, I would much rather go for brass or aluminium since they are very resistant to corrosion, or stainless if you need real strength.
ragnar
Tue Jan 30 2007, 06:57PM
Ya, drilling should not be problematic. If you centre-punch prior to drilling, the hole should get started pretty quickly with moderate pressure.
Use high speed steel bits and some lanolin or WD-40 lubricant (see which works best for you). If the PSU cases really do chew up your HSS bits, buy spares :D
Dr. Shark
Tue Jan 30 2007, 08:44PM
Drilling is in fact problematic, but for an entirely different reason. Because the material is so thin and soft, the drill bit easily catches and bends the metal, also the holes tend to come out rather triangular than round. Using a quality drill press and clamping the work piece in place is therefore recommeded.
My 2ct.
ragnar
Tue Jan 30 2007, 10:06PM
Of course you would clamp the metal down to a "spoilboard" (flush against a disposable sheet of scrap wood) to prevent burring on the underside.
If necessary, you could clamp a spoilboard on the top, too, to assist drill entry into the steel... After you drill, use a deburring tool, or a many-fluted countersink to neaten up both sides...
TheMerovingian
Wed Jan 31 2007, 09:32AM
Seems fairly simple to use that material. I have lots of these casings , waiting to end in a dumpster, so better to recycle them. Since making holes isn't problematic it would be a cheaper alternative than alluminium sheets. Also, being ferromagnetic, it will schield somehow the coilgun pulse field (If the casing would not collapse on itself cheesey , just kidding). The sharp edges would be a major problem for a handheld device. Also corrosion is scaring me a bit. Maybe a hybrid design (plexyglass-metal) would be the right choice. Anyway thanx for suggestions, all this will be useful.
