  • Guests: 46
Strong magnetic field accellerates evaporation?
CM
Sun Jan 21 2007, 12:44PM Print
CM Banned on April 7, 2007
Registered Member #277 Joined: Fri Mar 03 2006, 10:15AM
I replicated the simple experiment shown on the below link demonstrating that water is indeed diamagnetic. "When exposed to a magnetic field, water produces a weak magnetic field in the opposite direction. Also, this means it is repelled by a magnetic field."
To me, it was fascinating to watch the oil bubble slowly move toward the neo-magnet to fill the area created by the neo repelling the H2O, must be the kid in me, sometimes the simple stuff is the most interesting. This raised a question which I am posting here in case anyone has already investigated or run an experiment on this topic. Question: In an open air environment (one atmosphere) will a very strong neomagnet sprintzed with water... cause the water to evaporate more quickly (due to the diamagnetic effect), compared to a control where water is sprintzed on a similar size/shape non-magnetic item? I plan to run this experiment soon, but I'd love to hear some predictions. CM
Tesladownunder
Sun Jan 21 2007, 04:03PM
I once tried a can crushing coil firing below a narrow water container about one foot long by one inch by perhaps 1/2 inch. It was a sensitive setup and could pick up footsteps on a concrete floor by the ripples. Firing several Teslas at it had no effect. It had a shield to prevent any acoustic wave effect.
I haven't tried the icicle or oil drop one though. It seems ice is diamagnetic as well.
Can't see why it should affect evaporation though.
What is much more dramatic is the electrostatic attraction of deionised water.
I'll have to try the oil effect.
Peter
