  • Guests: 35
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
quick questions on eagle
Electroholic
Mon Jan 15 2007, 12:41AM Print
im new to eagle, and i need a double layer board with like massive ground planes around my traces to minimize inductance, how do i do that.
the auto route button only give me traces.
Thanks.
Mon Jan 15 2007, 03:45AM
You can use the 'rect' tool (15th down on the left) to manually put in shapes, or you are supposed to be able to use the polyogn tool to draw a shape, then use the name tool to name it gnd, then it should fill in (but sometimes it doesn't work)
Electroholic
Mon Jan 15 2007, 11:59PM
cool thanks, i'll try that
Electroholic
Fri Jan 19 2007, 11:01PM
Sorry to bother you guys again, but here are the problems that Im having.
The "rect" tool seems to have a very large increment, and is leaving a very large gap between my traces and the ground plane. Can I change the setting on that?
And the "polygon" tool just doesn't seem to work at all, it keeps telling me that i need at least 3 points, which I'm pretty sure I have, it even highlighted the polygon for me.
What should I do?
Do they not work on the freeware version?
Sat Jan 20 2007, 01:22AM
you use the 'change' tool (looks like a wrench). It is something like isolate, select a different value and then click the polygon.
In an unrelated note, your eagle seems to act very differently than mine. when I create a rectangle it covers up all of the traces, and I never get the polygon 3 point error.
Try making one by clicking once, dragging the mouse at a diagonal (to make a L shaped wire) then double clicking. It should close and make a triangle. Then name it ground and hope that it fills in. Also, you might try turning on orphans (in the change menu).
Sat Jan 20 2007, 09:56AM
Hi,
The way I do ground planes, or any large area of copper, is to draw the whole extent of the area you want with the polygon tool, and then tell Eagle that you want this whole mess connected to net GND (or whatever net you do in fact want) using the same tool that's used for changing component designators. Then click the ratsnest button and the shape will be filled in and trimmed so that it stays the right distance from things that it's not meant to connect to.
As you can see, Eagle is kind of built on the assumption that you entered your circuit in the schematic editor, so it knows what tracks belong to what signals (or nets as they're called). It is also kind of weird to get used to. I've used it to design 4 layer boards with 128-pin ICs, so it does work. But the autorouter sucks mad so I do all the tracking by hand.
Tom540
Mon Jan 22 2007, 08:40PM
Tom540 Banned on 3/17/2009.
You could always DL the free version of PADS router. It is in my opinion and many others, is the BEST PCB layout software money can buy. As long as you only wanna make small boards it'll work. I think the part count limit is 30.
-Tom
Hazmatt_(The Underdog)
Fri Oct 12 2007, 07:24AM
I'm trying to use Eagle but the #$%# program won't let me delete my mistakes or move components around, any suggestions?
I already tried the help, but it was no help.
I like Winboard a lot more but I can't get the part val and part ref white so it won't print, so i'm stuck between something I can use but's wrong, and something I can't use.
Matt.
Fri Oct 12 2007, 08:10AM
You can only 'delete' stuff from the schematic editor, if you want to get rid of a trace on the PCB you have to use the 'ripup' tool.
To move parts you just use the move tool, and click on the little cross hairs for the component (make sure that tplace/bplace layers on on)
Avalanche
Fri Oct 12 2007, 05:21PM
It should be the same in most packages, it's usually called a 'copper pour'. You shouldn't have to even route the ground at all, just specify a copper pour area set to attach itself to your ground or 0V net, and then pour copper. Hint - there should be an option to leave thermals around the pads which do connect, otherwise it is impossible to solder because the huge copper ground plane acts as a heatsink for your soldering iron! You specify the distance between the copper pour area and the unattached nets somewhere in your design rules.
I'm currently laying out a large 4 layer board at work with a 16 bit micro and 64 ICs, and auto-routers are banned where I work (to the point of disabling them on all the machines). I totally agree! The middle two layers are used mostly for power distribution and ground, and the copper pour is used on both of those layers - simplfying the routing because it leaves only the signal traces to route on the outside!
