  • Guests: 36
putting a cap on the peak capacitor voltage
Tue Jan 02 2007, 10:31PM Print
I know that the voltage on a capacitor subjected to a step-impulse is
V = Vmax*(1 - exp(-t/RC)) where Vmax is the charging voltage.
Is there a formula when the charging function is a rectified sine function? I want to know the theoretical expression for controlling the peak voltage I can obtain on a capacitor if it is constantly being discharged by a load resistor while charging.
If I remember correctly from mathematics I should be able to deveop a laplace transform for the RC circuit and apply a sine function. I just don't know where my book is now. If I find it I will post my own solution.
Edit:
Not a transform function, but this may be close enough:
Wed Jan 03 2007, 02:38PM
A rectified sinewave feeding a capacitor and load is not a simple analysis;
the reference that you gave assumes zero source/diode/capacitor impedance - which is unlikely,
With very light loading there will be almost no ripple and Vdc = srqt(2) x Vac
Useful for instrumentation purposes.
The load (resistor) is to allow Vdc to decay quickly enough to follow decreasing changes in Vac
Increasing Vac will immediately result in increased Vdc.
With heavy loading such as a simple transformer/rectifier/capacitor/load
the waveforms (especially current) are quite complex so they are normally considered separately;
-Ripple Voltage (approximated as per the reference you gave)
Required to ensure a minimum source/supply voltage and appropriate ripple rejection.
-Ripple current to choose capacitor size/type
-dc current to choose the rectifier(s)
-Transformer regulation to estimate dc output drop with increasing load
-etc. etc.
Usually take Transformer VAR = Vac x Iac, Vdc=1.4 x Vac and Idc=0.62 Iac
Why do you need an analytical solution?
Simon
Thu Jan 04 2007, 01:20AM
IamSmooth wrote ...
The trouble is, the Laplace transformation is for linear analysis. A diode used for rectification is very nonlinear.
I think I know what you mean but would you please draw the exact circuit you have in mind?
Thu Jan 04 2007, 05:03AM
Why? I am just curious about how to model a theoretical circuit to real-world constraints.
This is what I was talking about and I wanted to know if there was a way to pick R such that the average DC value could be known:
IamSmooth wrote ...
1167886916 190 FT17015 Circuit2
Simon
Fri Jan 05 2007, 05:11AM
The only reason the average DC value of the output would be different from that of a usual rectified sine wave is if the voltage source has an output impedance. Of course, it does but you need to model that.
To work this out in practice, I'd think about the long term average current entering and leaving the circuit.
Edit: That first paragraph isn't completely true. I've also been thinking about how to work this out analytically. There might be a simpler way but this is complicated. I really suggest you play with a simulation but if you really want I'll post some of my thoughts.
