  • Guests: 41
measuring AC voltage with a DC meter
Sun Dec 31 2006, 11:04PM Print
I need to measure an AC signal that is between 0.5-2v. I am finding it difficult to come across an AC voltmeter in this range at a low price. However, I do have a DC meter. So, I set up a test circuit. I used a 120v/24v CT transformer and connected it to a variac and set it so I have 23v on the secondary. I connected a 1n4007 from each hot lead to the center-tap to create a full-wave rectifier. I connected one end of a 30k resistor to the two diodes and the other end to the center-tap. This, of course, cuts the voltage in half and the diodes have a 1.1v voltage drop. When I connect a digital voltmeter across the resistor and the center-tap I only measure 10v DC.
I guess that if I just use half-wave rectification between the hot leads I won't cut the voltage in half. If I place a capacitor across the load I can get a value that is close, but the capacitor captures the peak and not the RMS value. Notheless, I will still have the voltage drop of the diode which is significant for the voltages I intend to measure. Is there a better way to do this or a way to refine my approach?
Mon Jan 01 2007, 12:24AM
To measure small ac voltages you need to use a more advanced diode than a block of silicon.
The simplest way would be to switch over to a germanium diode, but you will still have on the order of .2v of drop across them...
After that there are op-amp based solutions...
Hazmatt_(The Underdog)
Mon Jan 01 2007, 12:55AM
why not use a precision rectifier?
Mon Jan 01 2007, 03:28AM
The 'op-amp based solutions' I posted is basically a pair of precision rectifiers with a little extra to make them work for full wave rectification...
But if you can tolerate the voltage drop, a simple Ge diode is a bit simpler wink
Mon Jan 01 2007, 04:17PM
Why not just use a digital multimeter? Even the cheapest ones measure AC voltage using a precision rectifier. The only gotcha is that the internal circuit full-wave rectifies and then averages the signal, and then scales it by a factor of around 1.1 (IIRC) so that the display reads the correct RMS voltage when the input is a sine wave. It won't read the RMS correctly for other waveforms.
Tue Jan 02 2007, 01:54PM
Using a digitial multimeter defeats the purpose of "doing it myself." I think I will go along with using Schottky diodes. I have some with Vf = 0.2v when I measured them a while ago.
