  • Guests: 60
All kind of gate drivers etc
Reaching
Fri Dec 29 2006, 01:16PM Print
while i was searching for some new ideas to drive my large igbt bricks i found an interesting paper about gate drive techniques etc,
i think it´ll be useful for many. wink especially page 14 and page 31/32 are very interesting
CM
Fri Dec 29 2006, 03:35PM
CM Banned on April 7, 2007
Registered Member #277 Joined: Fri Mar 03 2006, 10:15AM
CM
Fri Dec 29 2006, 06:06PM
One thing I noticed was that it never mentioned driving all 4 transistors from a single gdt... Maybe we have things all wrong and should split our bridges in half and use 2 gdt's, as opposed to stacking a whole bunch of drivers to get a single gdt to do it. confused
If only I wasn't an 8 hour drive from my lab...
Reaching
Fri Dec 29 2006, 06:16PM
one interesting thing is to use a pnp transistor to turn off the mosfet/igbt. with this circuit the driver only needs to source the power for the turn on and you get faster turn off times, and it works cheesey
Tom540
Thu Jan 11 2007, 04:14AM
Tom540 Banned on 3/17/2009.
Today at work I dug up a schematic of a full bridge of mosfets used to drive a 100KHz ferrite core transformer in flyback mode. The bridge is part of a redundant module that goes inside of some awesome power supplies. The bridge uses IXYS 50 amp mosfet. I think they are 50n something.
Anyway I noticed they had and interesting gate drive method and I thought it might be worthwhile to try it out for a TC. The company I work for now makes some very beefy power supplies for pretty much any type of application. Some supplies are around 30KW! I attached a screen shot of the gate drive method used. It looks similar to some of the things on that article. This bridge used two gate drive transformers in exactly the way we have been using them for coils. The gate drive Xfrmrs only had 6 turns on them. Someone should give this a try. I might try it myself if i don't get too lazy this weekend
1168488872 487 FT19319 Gatedrive
