  • Guests: 49
Fibreoptics and sunlight
Tesladownunder
Sun Dec 24 2006, 11:15AM Print
While many of the 4HV members are snowed/fogged in I thought this might bring a little warmth.
I found an old dental fibreoptic unit for UV curing of dental bonding agents. Normally run from a halogen lanp and a UV filter. In the same box I had a 6 inch quality first surface spherical mirror. This gives about 0.0088 sqr meter area. Sunlight is about 1kW per sqr meter so about 8.8W of light available. Compare that with a laser of similar power for burning ability. It burns wood very smartly.
Focussed very roughly on the end of the fibreoptic it gives enough power out the other end to give a rapid large hole in black plastic.
Peter
1166958929 10 FT0 Fibreopticsdentalsetup
1166958929 10 FT0 Fibreopticsdentalburn
Madgyver
Sun Dec 24 2006, 04:09PM
Very nice. I wonder how fun it must be, If you can get hold (or build) a much bigger mirror.
Marko
Sun Dec 24 2006, 04:17PM
That's cool. I wondered if an IR soldering 'gun' could be made of those fiber cables, if enough power is pumped into it with large infrared bulbs. Bulbs are much trickier to focus than sunlight, though...
stop4stuff
Mon Dec 25 2006, 10:03AM
stop4stuff Registered Member #64 Joined: Thu Feb 09 2006, 06:25AM
great fun TDU... check out Link2 & Link2 for a homemade 10 foot dia mirror
merry xmas,
paul
Marko
Mon Dec 25 2006, 12:35PM
Or this Link2 for a collosal death ray of doom.
Though I don'tt hink of any practical use with sun alone...
Tue Dec 26 2006, 07:09PM
As you increase the diameter you will want a long focal length to allow th fiber to accept the light
look up "acceptance angle" Link2
Tesladownunder
Wed Dec 27 2006, 11:29AM
This was just a quick test and I rapidy melted and charred the entry point of the plastic fibres. Still interesting while it lasted. It would be interesting to get that power down a proper optical fibre link.
Peter
