  • Guests: 32
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Best use of 20*15000uF 400v Capacitors?
LarsE
Wed Dec 13 2006, 12:05PM Print
LarsE Registered Member #153 Joined: Sun Feb 12 2006, 03:44PM
I just got about 20* 15000uF 400v capacitors for about 7USD each, they are only used for about 10 hours so they are almost new.
I haven't decided yet what i going to use them for. The first thought was to build a rail-gun or a bigger disk-launcher with them but i not shure.
Anyone got a god idea what to do with them?
1166011457 153 FT0 Capacitor
1166011457 153 FT0 Capacitors
Tesladownunder
Wed Dec 13 2006, 01:47PM
Catching the voltage reversal into an inductive load is going to take some pretty hefty diodes.
They should make for some impressive effects like blowing up steel wool or aluminium.
Here is 1.5kJ blowing up 1 inch of aluminium foil. You should be able to do better.
A lot better.
Peter
1166017643 10 FT18901 Hvcoilgunflashb
Wilson
Wed Dec 13 2006, 02:13PM
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
wow....thats crazy...i had to re-read the title just to make sure I'm wasn't seeing things. They're inverter grade caps, judging from the size of the terminals. It could make a ripper rail gun if you could design one correctly amazed
Andrea87
Wed Dec 13 2006, 05:04PM
Andrea87 Registered Member #494 Joined: Thu Nov 09 2006, 02:42AM
Woot! that a so huge bank! At 380V 0,3F you get 20KJ, I would say a good serial-parrallel circuit (why not 4strings of 5 caps for 12000µF 2KV) should be veeery good for a giantistic railgun, or a coin shrinker, or maybe a wire exploder... but I would prefer to put these beasts on a railgun, a biiiig one! it would be able to pass thin walls of wood, or maybe better...
ShawnLG
Wed Dec 13 2006, 05:22PM
You can build a huge coilgun which can propel huge bolts.
Wed Dec 13 2006, 08:24PM
Coin-Shrinker! 20kJ should be enough to shrink any coin, even 10kJ would probably be enough. You could also build an arsenal of "low" power coil guns, and still be able to upgrade your disk launcher. The possibilities are endless!
Just out of interest, where did you get those capacitors?
Wed Dec 13 2006, 10:26PM
Best use of capacitors: Sell them to uzzors at a profit? wink
LarsE
Thu Dec 14 2006, 04:11AM
Thanks for all the ideas everyone.
How god results with coin shrinking can i expect with electrolytic capacitors, i thought they was a little bit to slow?.
Maybe i go with the rail gun, i thing i got some 5*20mm copper busbar that i can use to buil the capacitor bank and 8*80mm for the rails.
So if anyone have some railgun building tips i appreciate it. cheesey
uzzors wrote ...
I won an action with 5 caps and the seller asked me if i wanted to buy all the other caps he had, and i did. I think they where removed from some big ABB switchgear where they was used as motor backup.
The Switchgear was going to be scraped after some testing i an testlab.
Tesladownunder
Sat Dec 16 2006, 04:27PM
LarsE wrote ...
Highly unlikely to crush a can properly, let alone a coin. Electrolytics discharge in perhaps 1ms if you look at Jason Rolettes railgun. Pulse caps discharge in 30us. Also electrolytics don't hadle voltage reversal.
For example Sam Barros has a 3kJ cap bank which made a mild dent in a can about the same as 300J from my cap bank.
Peter
Sat Dec 16 2006, 06:09PM
I suppose you could use MOTs with the capacitors in series to make an 8 kV dc supply
for a dc-resonant-charging TC. (absolutely lethal/terrifying stored charge though)
Or design/build/test/sell 20 coilguns?
Or design/build/test 20 power-factor-corrected 330V power supplies, they'd probably sell well too.
Or 20 x 12Vdc to 400V dc then back to 14V dc smps for car stereo Uber-capacitors.
Or wire exploding / foil detonators/slappers
