  • Guests: 46
Nitrogen Laser Information
95se5m
Tue Feb 21 2006, 04:39PM Print
95se5m Registered Member #197 Joined: Fri Feb 17 2006, 09:55PM
Lo all. I picked up a Nitrogen Laser from E-bay, it's a nice unit, self contained, however there is no information anywhere on the net due to the fact it's an OEM unit. Anyone maybe have any information on what the inputs are on this thing? It's got 2 inputs and a ground as well as what looks like a data out for an o-scope, I need to know which is the positive and which is the trigger so I do not blow this thing to kingdom come. I know it's a 24V input, just it's encased in an orange resin and I can't trace the wires to find out myself.
Anyone see or have one of these e-bay units and know what's what?
1140539921 197 FT0 3d8916c
Thanks in advance,
Jim
Carbon_Rod
Tue Feb 21 2006, 11:09PM
The 24vDC is common for military and industrial products. The design looks like it has two exposed micropositioners on the ends of a low-volume production aluminium case. If these turn out to be the reflectors on a module, then you may be able to read the model number off the inside core module for later replacement. If this entire unit is a replacement module you may be rather disappointed.
Good luck,
