  • Guests: 55
Sick oscilloscope
McFluffin
Fri Dec 01 2006, 11:46PM Print
McFluffin Registered Member #119 Joined: Fri Feb 10 2006, 06:26AM
I have a Tektronix 2213 oscilloscope that started to act up a while ago. I think it was left on for a while, and then the next time I tried to use it, it had some problems as hopefully seen in the picture below. The traces no longer go across the entire screen. If you try to move them, they sort of bunch up. I can still get a signal on the working part, however. Does anyone know what might cause this or how to fix it? I opened it up, but did not see anything wrong such as blown capacitors like I was told to look for by several people. I looked through the operators manual and service manual which can be found at:
But have yet to find something that helps me as I am not very familar with the internal workings of oscillioscopes. From what I can guess, something is wrong with the horizontal sweep generator, but I don't know how to proceed from there. I would imagine that most things would require another oscilloscope to test, so any test might be hard for me to do.
Attached is a picture of the setup, a close up of the screen misbehaving, and a short quicktime movie of me moving the display around to show what is happening. I personally don't like quicktime, but thats the format my camera exports to and I don't really know how to convert it.
1165016695 119 FT0 Tek2213 1
1165016696 119 FT0 Tek2213 2
]1165016696_119_FT0_tek2213_broken.zip[/file]
Dr. Slack
Sat Dec 02 2006, 08:27AM
Rule out the simple stuff before diving deep into the circuitry. Is the "Beam Find" button stuck in, or is there a simple fault on the wires from that? That display is characteristic of what happens when you press beam find on a working 'scope, it clamps an off-screen picture down into the visible area so you can see where it went. If it was a fault in the X drive circuitry, you might expect an assymetric fault (from one rail going down), or a less well-defined clamping action on the trace. Try overdriving the Y inputs, a single fault is unlikely to clamp both X and Y, but the beam find will.
McFluffin
Sat Dec 02 2006, 06:33PM
Thanks for the reply. I can look internally to see if there is a beam find problem, but the beam find button when compressed makes them very small, like less than 1 division. I'll edit with an update when I can check it. When you say overdrive, you mean a "high" voltage signal? It will go off the screen on the Y inputs if that is what you are asking, such as if I increase the div/V or raise the voltage going in.
