  • Guests: 45
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Regarding fiber optics
|)4+80!|-|\\/
Sun Feb 04 2018, 07:03AM Print
|)4+80!|-|\\/ Registered Member #61803 Joined: Thu Sept 21 2017, 09:18AM
now, I 've tried to find HFBR-2412(which is what most of y'all use) for cheap quite a while now,
sadly i've failed
but, i've found thesehttps://www.ebay.com/itm/1x-HP-HFBR-2416TC-HFBR2416TC-Fiber-Optic-Transmitters-Receivers-Transceive/181821930653?epid=1929997036&hash=item2a556e7c9d:g:52YAAOSwLVZVvxh2
on eBay they're fairly cheap
Now, the question is will they work??
dexter
Sun Feb 04 2018, 11:10AM
I had the same problem as you - price
I fond this on eBAY:
which required a few additional parts because the output wasn't moving that much
1517741502 42796 FT181398 Opto
or maybe that was because of my red LED fiber optic emitter...
The one you found can also work.
What i advise is to test it in advance to see it it can drive a logic gate. If the output is to low use the circuit above
|)4+80!|-|\\/
Sun Feb 04 2018, 01:11PM
I don't think I'll be able to test
My parents won't let me buy it if I'm not 100% sure it works
So well ill
dexter
Sun Feb 04 2018, 05:00PM
is not that it wouldn't work... is all about if it requires a few extra parts or not
Mon Feb 05 2018, 05:18AM
I don't know what electronic component distributors you can order from, but Industrial Fiberoptics sells cheaper transmitters / receivers that use 1000um core plastic fiber. They are the cheapest transmitters / receivers you can get on digikey.
Loneocean's revision of the UD 2.7 driver board uses them as an option to replace the more expensive OPF-2412T or HFBR-2412T ST style receivers.
If you can order off digikey this is the pair you want:
|)4+80!|-|\\/
Mon Feb 05 2018, 04:26PM
Does the cheapness of these receivers make any difference performance wise??
Also, shipping to India is horrendously expensive!!! cry
Could you please direct me to any other source for these receivers and transmitters??
teravolt
Mon Feb 05 2018, 08:55PM
performance is not an issue for the interrupter of the universal driver. farnell electronics is closer to you in Europe. you could also use a fiber optic digital audio cable from junk like a busted tuner. another option is to use a well grounded peace of coax and make a direct connection. what do you have available where you live.
|)4+80!|-|\\/
Tue Feb 06 2018, 02:13AM
Coax is abundantly available to me
Also, I don't have any fiber optic thingies here in india
profdc9
Tue Feb 06 2018, 03:59AM
profdc9 Registered Member #58522 Joined: Tue Mar 15 2016, 08:33PM
Here's an idea: get a red laser diode module and modulate that, and use a phototransistor to pick up the signal. Forget fiber optics, go free space! It will have to be aimed carefully, of course. I found the following on Amazon India:
Modulated Laser Diode
Photosensor
You might be able to adapt these for the interrupter signal. Go wireless!
Dan
Hydron
Tue Feb 06 2018, 08:08AM
Hydron Registered Member #30656 Joined: Tue Jul 30 2013, 02:40AM
Or if it doesn't work - couple the diode/sensor through a piece of fibre!
If you do need to go for the TX/RX modules (and yes, we all complain about the cost, even in places where they're easier to get), then you may find that sellers on ebay/aliexpress offer cheap/free shipping worldwide.
