  • Guests: 36
My first DRSSTC
Maxitechnic94
Mon Jan 29 2018, 09:02PM Print
Maxitechnic94 Registered Member #58312 Joined: Fri Jan 15 2016, 09:07PM
Hello i'm Maxime, i never write on this forum yet, so today i show you my first DRSSTC that i've build during one year.
I have some question about it
Spécifications
• Inverter: half bridge IGBT IXGN60N60C2D1 600V 300A
• Bus capacitor: 2x 1000uF 250V in series
• Snubber: 4,7uF 400VDC
• Driver: UD1.0 with primary feedback and OCD
• MMC: 1.5uF 3kV, 2 in series for a total of 0.75uF 6kV
• Primary coil: Flat spiral coil 5mm Ø
• Secondary coil: 8x40 cm, 32AWG, ~1800 turns
• Topload: 10x40cm aluminum
• Resonant frequency: 180kHZ
A picture of my entire coil
1517242124 58312 FT0 Img 2793 2
I be able to produce a maximum of 70cm spark lenght at 300A ipk ( around 150us)
Here the spark
1517242795 58312 FT0  Mg 8144 Reduit
1517259472 58312 FT0  Mg 8131 Reduit
I have some question about the coil , if someone more experienced could answer and help me, it would be nice cheesey
My first question is about the bus capacitance, it seem that i don't have enough bus capacitance for this coil (2x 1000uf in series). Because after running the coil, the bus caps are quite warm. So I measure the voltage across it; at low Bps the bus voltage is relatively continue (bus is fully reacharged after each pulse), but at high bps the voltage is clearly not continue, more like rectified 50hz. I planned to add a capacitor across the 2 in series but how much capacitance ?
I run the coil at ~150uS and 900Bps
By adding extra capacitance I'm afraid to add more parasitic inductance to the bridge.. do i need more snubber to thwart that ? (4.7UF already here)
My second question is about the primary circuit impedance. My mmc is 0.75uF and primary coil around 1.1uH, this is a realtively high impedence (~12) i achieve 300A in 9 cycles , but if i lower the impedance (more mmc) could I transfer the energy faster? I do not know if it could improve performance..
An other question is how far can i push the pwm? , I often see that drsstc are driven aound 10% max pwm or 20% but i don't know precisely for my coil.
My supposition is that Pc the average power dissipation of igbt should not exceed their maximum according to datasheet. (for my igbt it's around 480w) The power dissipation depend of: the average current (300A x PWM%) and Rg the internal resistance of igbt (the higher the gate voltage, the lower the resistance) by following the formula P=RI^2 we know the power dissipation ? but how to determine Rg ?
I have a last question (again cheesey ) about breakout point
I noticed that when i put a long breakout point (20cm) the spark is more easly produced at low on-time/ low bps , than with a short output point (5cm). But with a short breakout, when I'm increasing the On-time / Bps, the spark suddenly growing and seems to be slightly larger.. why?
setup
1517243538 58312 FT0 Img 26271
Uspring
Tue Jan 30 2018, 04:38PM
During the burst you're drawing a peak current of 300A. Assuming a linear rampup of current that is an average of 150A. The average of a sine wave is 2/pi of this so about a 100A. For a burst length of 150us, that would amount to 15mC of charge, i.e. a voltage loss on your bus cap of 15mC/500uF = 30V for a single burst. At 900bps you have 9 bursts (=270V loss) before a full wave rectifier recharges the caps. So yes, the bus caps are too small.
The numbers for your primary tank seem wrong. Primary impedance is sqrt(L/C), i.e. about 1.2 ohms. 300A through a 0.75uF cap at 180kHz would just cause a voltage drop of 350V (?). That wouldn't require a 6kV MMC.
Instead of looking at the emitter-collector resistance use the datasheet for the emitter-collector voltage drop for the currents you are using. From there you can calculate the power dissipation.
Maxitechnic94
Tue Jan 30 2018, 07:33PM
Thanks you for your reply
Oh damnit angry I made a mistake I meant a mmc of 0.075uF (2x 0.15uF)
So how can i determine the require bus capacitance?
Uspring
Wed Jan 31 2018, 11:43AM
Depends on how much voltage drop between the recharging periods from the line voltage you want to tolerate. I'd go for at least 3 times the present capacitance.
