  • Guests: 39
Something weird about primary oscilloscope traces
|)4+80!|-|\\/
Sun Jan 14 2018, 01:33PM Print
|)4+80!|-|\\/ Registered Member #61803 Joined: Thu Sept 21 2017, 09:18AM
Well, when checking out other DRSSTC's
I've found something which I think is quite odd
In almost all the traces found online, there's a point when the IGBT starts turning off and then just stops doing that and goes back to the on stage
I've attached a few photos to clear my point up a little.
2ohm
1515936835 61803 FT0 Ds1z Quickprint92 Small
Hazmatt_(The Underdog)
Sun Jan 14 2018, 05:45PM
You know that the SSTC designs use current feedback from the tank right?
The whole point of having current transformers on the tank is to provide feedback, and this just looks to me like the tank current reached maximum safe current, and so the bridge stopped driving the tank, nothing unusual there.
Sun Jan 14 2018, 10:40PM
That is the point where the energy transfer 'flips'. In the first image, for the first 5 cycles the switches are being driven and are transferring energy from the DC buss into the resonator. At the 6th cycle the gate drive the switches is turned off, and the switches are 'freewheeling' (acting like a bridge rectifier) allowing the energy stored in the resonator to be returned into the DC buss. There is a 180 degree phase change in the phase of the current/voltage flowing between the resonator and the buss (corresponding to the flip from positive to negative power transfer) and this is what you see in the voltage waveform.
|)4+80!|-|\\/
Mon Jan 15 2018, 10:55AM
... wrote ...
Why is this freewheeling being done??
GrantX
Thu Jan 18 2018, 08:31AM
The freewheeling just happens naturally. The gate drive turns off, and then the energy in the resonant tank "rings down." The current in the primary circuit flows back through the diodes in the bridge, 180 degrees out of phase compared to the driven waveform.
