  • Guests: 67
Help with SSTC capacitor value
SparkyProjects
Tue Jan 09 2018, 12:06AM Print
SparkyProjects Registered Member #58047 Joined: Wed Nov 25 2015, 12:46PM
I'm building a SSTC coil, it will be full H bridge, power supply will be from the mains at about 240V, full bridge rectified and smoothed, so DC rail should be about 330V, i'm thinking a minimum of 500V capacitors, though i do have some 1.5KV caps from a previous coil build, secondary is 6" x 36", resonant frequency will be about 130KHz
What value should the secondary capacitor be ?
Tue Jan 09 2018, 09:14AM
I think you are getting some things mixed up here.
A SSTC does not have a resonant primary circuit, only a DC blocking capacitor in series with the primary coil.
The secondary capacitor is the topload and the self capacitance of the secondary coil.
SparkyProjects
Tue Jan 09 2018, 09:29AM
But you still didn't answer the main question. what value capacitor ?
dexter
Tue Jan 09 2018, 11:10AM
are you talking about the electrolytic cap/s on the DC buss or the DC blocking cap in series with the primary coil?
the value for the electrolytic is dependent on how much current your bridge will draw and a voltage rating of 450V is enough for rectified mains
for the DC blocking you need a foil cap of about 1uF 600VAC or you cab choose a value that is far enough from resonance and for your chosen secondary resonance has a small impedance
SparkyProjects
Tue Jan 09 2018, 12:24PM
dexter wrote ...
Thanks, i was talking about the DC blocking cap, I included some specs in case it was needed, and as you mentioned, resonance has a bit of an impact, i will try the value you suggested once i get around to building the circuit.
