  • Guests: 35
01/13 si2030 (62)
Digital potentiometer for AC signals with low THD
Linas
Mon Feb 01 2016, 10:52AM Print
I have such a strange problem:
In my design, i need to control volume from microcontroller. All sounds OK, but audio sygnals are completely AC (+-1V).
I need at least 100db dynamic range, because this is what i get from my dac, but i was unable to find any digital potentiometer that does that, closest is AD5262 , and it can only give 0.014% THD 77db
Can any one give me idea, how to control sound, with more dynamic range, with complete AC input ?
Mon Feb 01 2016, 11:18AM
Just to check, what is the maximum ac signal pk-pk voltage and bandwidth ?
Mon Feb 01 2016, 01:00PM
It seems unlikely that you will find a single chip solution that will give you that kind of performance.
There is a reason that people use relays and resistor banks for attenuators, they really are hard to beat in terms of performance.
You might try looking for 'programmable gain amplifiers', there are some pretty high end devices like the PGA281 which claims 0.0001% nonlinearity over a +-18v swing (!), although it doesn't have many gain steps and you will have to mess around with the levels to make use of them all (it goes from gain = 0.125 to 128 in 11 steps).
Linas
Mon Feb 01 2016, 02:23PM
... wrote ...
0-20kHz ans signal should be around 1V or more. ( what is better for low noise)
Yes, VGA would be nice, but i need to reduce gain, not apply it !
johnf
Mon Feb 01 2016, 06:25PM
Try a PWM or DAC to a LED's that shines on a LDR's set up like a pot
Mon Feb 01 2016, 07:17PM
100 dB SNR implies En = (1v/2.sqrt(2)) x 10^-5 = 3.5 uV rms noise voltage
and En = sqrt(4.k.T.R.BW) = sqrt(4 x 1.38 x 10^-23 x 300 x R x 20,000) = sqrt(R) x 18 nV rms
R <= (3500/18)^2 = 37 kOhm
and, good op-amp En = 1 nV x sqrt(BW) = 141 nV rms = negligible
OK, sanity check pass
NEXT: can you measure if you achieve your goal ?
So a resistive divider is feasible provided that the resistance is less than 37 kOhm effective.
I would use signal relays with gold plated contacts (because mercury-wetted are uncommon and a nuisance)
but mosfet switches may be adequate, not sure if low-noise switching mosfets are available
and a resistive divider.
That would be bulky, costly and unreliable if considered commercially.
Try contacting Analog Devices, (or Maxim, or even Texas Instruments, Vishay or maybe Infineon) etc.
for technical help, they probably have something.
100 dB isolation is quite challenging, even for an attenuator, due to parasitic coupling,
intelligent routing of conductors, digital and analogue 'earth' and lots of screening probably required.
Please publish your methods and results, even failures, so I (we) can learn.
Sigurthr
Tue Feb 02 2016, 12:46AM
Is it bad the first "solution" that came to mind was a magnetic amplifier? Haha.
In all seriousness though it may be worth doing a stepper motor controlled potentiometer.
Hazmatt_(The Underdog)
Tue Feb 02 2016, 04:07AM
I would implement a Pi type attenuator with two N channel fets, and a P channel fet as the signal pass element. This makes a voltage controlled pad. You may have to do some clever things with the voltage control to get linear attenuation though, and its fairly simple idea, but the implementation will be difficult.
It will probably require some op amps to swing voltage from negative to positive to give you full control of the fets.
On a positive side, if one Pi stack only gives you 50dB attenuation, you can stack two together with the same voltage control lines, so it can be cascaded.
On the downside, the fet selection may be difficult. Rds On will need to be low, like 30 ohms.
The fets may also add noise to your signal, but I don't know, I've never tried it. I've only done a SPDT fet switch for audio, but it seemed to work okay.
Linas
Tue Feb 02 2016, 06:49AM
At work i have scope with -130db noise floor
So i think i must use DC blocking capacitor, to make it work. Best idea would be ( i think ) is to take 1k digital pot that can operate at 0-10V, use another one good 1k resistor to Vref, lets say ultra stable 5V supply ( i have nice LDO for that, LT3042 :) and all chips will be using this LDO to make it perfect ) , and put like 10-100uF capacitor ( film, not X7R or anything stupid, maybe good tantalum) into middle point, and that should work a treat. I am right ?
1454395741 1143 FT175214 Digital Pot Amplifier
op amps will be all OPA1612AID and similar grade
hen918
Tue Feb 02 2016, 08:23PM
0.014% THD is practically inaudiable. There are very few humans on earth (or possibly none) who can tell the difference between 0.14% and 0.014% THD in a blind test. (Except if it was made up of entirely one harmonic, possibly)
