  • Guests: 43
01/13 si2030 (62)
Microwave sintering.
Chris Cristini
Fri Jan 29 2016, 06:36PM Print
I have access to These large Magnatrons Link2 And all of the electronics necessary to make a Microwave Sintering Chamber so I can finally make my Transformer designs from long ago. Link2 :) Maybe if it is possible I will make them at home and possibly for others who have a custom ferrite design they would like to try of course they would be poor quality so they would be free.
Sat Jan 30 2016, 08:58AM
Sounds intriguing.
Carbon_Rod
Sat Jan 30 2016, 11:13AM
I tried something similar a few years back, and confirmed the NASA paper was correct in stating cracks in ceramics were almost unavoidable due to the uneven heating.
If you can get a volume larger than around 16^3cm to stop cracking I'll be impressed...
wink
A laboratory grade furnace with sintered medical grade zirconium was much less hassle.
Best of Luck,
Rod
jpsmith123
Sat Jan 30 2016, 04:25PM
I'm curious, what are you trying to do that you cannot use commercially available ferrite cores, e.g., from TSC International?
Chris Cristini wrote ...
Carbon_Rod
Sun Jan 31 2016, 01:08AM
They are probably looking for a high frequency Ni ferrite in the power class where sub-MHz Manganese ferrite typically dominate.
wink
