  • Guests: 40
Leaf Blower and Impeller questions
Pete
Wed Nov 01 2006, 09:41PM Print
Pete Registered Member #106 Joined: Thu Feb 09 2006, 09:39PM
I am trying to design some basic diagrams and outlines for an idea I want to try. IT involves a leaf blower. For the life of me and all the Google searching I have done, nowhere it seems can I find a darn leaf blower diagram, schematic, or even basic dimensions. All I really want to find is the impeller drawing, size and perhaps the blade count and if they are curved or straight blades.
Does anyone have some good pictures or links to something? I really am at a loss. Short of buying a leaf blower and ripping it apart. I will be going back to the U.S. on Monday for 3 weeks and I would at least like to have some rough idea of what I will be having to design around.
Thanks a lot everyone.
Pete
AndrewM
Wed Nov 01 2006, 10:13PM
They are curved. Some are squirrel-cage type, others are centrifugal.
Whats this for?
Pete
Wed Nov 01 2006, 10:17PM
See you are perfect for this. I was sort of hoping you might answer. I want to build a circular wing around the outside of the spinning edge of the blower to see how much lift I would get.
AndrewM
Thu Nov 02 2006, 01:45AM
interesting, could be neat, although you still have the torque issue to deal with. look up the 'channelwing' concept and try not to be swayed by the pseudoscience; its a similar 'move the air, not the wing' idea
leaf blowers will be hit or miss, so you're going to have to poke around. most seem to have a rotor that falls in between squirrel cage and centrifugal, that is, the blades extend in the radial direction, but not all the way to or from the center.
Pete
Thu Nov 02 2006, 02:37PM
Huh. The Channelwing. That was interesting. But I really think it is the speed of the air, not the speed of the wing. cheesey
Well, I have been drawing up my plans in AutoCad, so when I get home tonight in about 6 hours, I will try to finish them up and post them so you can see what I'm looking at. Maybe give me some critisizm. Thanks. :)
Pete
Thu Nov 02 2006, 02:44PM
Surely the lift from your channelwing gizmo will be pretty much the same as the thrust you get from the unmodified leaf blower?
Pete
Thu Nov 02 2006, 09:31PM
Here is the pic I promised.
1162502526 106 FT1630 Circlewing
I will try to give a 3D exploded and combined view later.
What you can see is that I wil take apart the leaf blower leaving the motor and the impeller attached. I will fabricate a stator of some sort to direct the air over the wing section. The wing will be fashioned out of probably plexiglass and formed using my oven at low temperatures. I might even decide to build a vacuum forming machine.
The motor will turn the impeller, push the air out the periphery, through the stator and over the wing. Hopefully this will have a measurable amount of lift. I am not anticipating anything really exciting, just a proof of concept idea. I don't think that a 2,000 watt leaf blower will lift itself off the table into flight, but fun none the less.
Pete
Thu Nov 02 2006, 10:54PM
Well, Custer claimed between 8 and 13lb of lift per horsepower, and 2000w is just under 3hp. Even if the motor was only 60% efficient and you were towards the 8lb end, it should come close to lifting itself.
Coronafix
Fri Nov 03 2006, 02:00AM
here is something you might find interesting.
uses the coanda effect.
He shows how to make one as well.
