  • Guests: 66
01/13 si2030 (62)
Detecting the amount of charge: MOSFETs?
OScoder
Tue Oct 31 2006, 11:15PM Print
OScoder Registered Member #304 Joined: Sat Mar 11 2006, 02:19PM
Hi,
I am studying AS-Level physics, and for coursework I have to make and test a sensor -> I think I'm going to try and make one that detects the amount of charge at a terminal so you could, say, work out the voltage a battery will give out, etc. Note this is not a voltmeter - the key is measuring static charge without drawing a current.
Would MOSFETs be useable for this? I've read that they let a varying current through depending on the charge a their gate. Are there other ways of doing this? (It'd be better if you don't recommend one over the other though, as deciding that is part of my coursework!).
Thanks,
OScoder
Tue Oct 31 2006, 11:38PM
Well there will always be a little leakage current just from like the plastic arround the leads and whatnot, but in most cases it can be ignored. When we are taking less than a hundred volts I can't say that will hold true.
As to other devices... I can't really think of anything...
Good luck!
Simon
Wed Nov 01 2006, 12:02AM
To make this MOSFET thing work, you'd need to take all the charge that's on what you're measuring and put it on the MOSFET gate. You might as well put it onto a capacitor and measure the voltage on it, instead. Measuring a charge that's where you want it isn't a problem at all.
The hard thing is measuring a charge that's in an arbitrary environment. All you can measure remotely is the electric field from the charges, such as by measuring the voltage between two points. Capacitance is what defines how voltage and charge relate so without knowing the capacitance, measuring the voltage won't be much help.
Theoretically, you could measure the charge without affecting what you're measuring much. (Kind of like how a thermometer measures the temperature of something without affecting it much.) You could measure the voltage and take some charge off the thing (such as by sticking a tiny capacitor on it briefly). The capacitance of the thing should be the change in charge (the charge on the capacitor) divided by the change in the voltage (of the thing you are measuring). This will let you work out the original charge.
That's getting way too complicated for what you're doing, I'm sure. I wrote this so you might get a better idea of what you're looking for.
I'd say do something simpler, but still cool. Something like a speedtrap or maybe even a laser ranger.
Thu Nov 02 2006, 11:24AM
A common digital multimeter already works pretty much the way you describe, though it measures voltage, not charge. The circuit inside a DMM (like most chips nowadays) is made with MOSFET technology, so could happily function without drawing any current from the voltage under test.
In practice, the guys who make DMMs deliberately connect a resistor across the input, because it makes the meter more convenient to use and harder to destroy by static discharge. 11 Megohms is a common value.
