  • Guests: 35
CAPACITOR-TO-CAPACITOR CHARGING EFFICIENCY LIMITS
Signification
Thu Dec 03 2015, 12:57PM Print
I have tried to charge one capacitor from another in various ways, mainly a crude switch or resistor. I have never seen even 50% energy efficiency in the transfer. Is there some kind of Joule efficiency limit in this type of charge transfer? Does anyone know of a way to get >50% direct transfer of energy between even two 'identical' caps?
Thu Dec 03 2015, 02:24PM
Yes, but it's all about conservation of charge.
As a simple example, let C1 and C2 be identical 1 F capacitors sharing a ground terminal.
Initial voltage are 1 and 0 volts. Charges (Q=CV) are 1 and 0 coulomb.
Energies (E=CV*2/2) are 1/2 and 0 joule; total energy 1/2 joule.
As charge moves from C1 to C2, there's a point where each capacitor has 1/2 of the charge, at 1/2 volt.
Energies are 1/8 joule per capacitor, 1/4 joule total.
It's the minimum energy static state; we could leave the capacitors connected together.
If charge continues to move in the same direction, eventually all of it is on C2 and none on C1.
We are back to the initial 1/2 joule of energy, all on C2.
But it takes work to move charge from a lower to higher voltage.
We can move most (ideally, 100%) of the initial energy from C1 to C2 by making the connection through an inductor.
Close the switch for just 1/2 cycle of the RLC (ideally, LC) resonant frequency.
At mid-transfer, when the voltages are equal, the "missing" energy is stored in the inductor.
How long would the whole transfer take with an ideal 1 henry inductor?
DerAlbi
Thu Dec 03 2015, 03:32PM
You have found the "Capacitor Paradoxon" (just google it)
Half the energy is wasted inevitably in the ESR. (if there was no ESR the current would be infinite. thats impossible too, so dont even start a theoretical case without ESR)
The way to go is to make the resistance imaginary as klugesmith stated by using an inductor (and i would like to add a diode to prevent oscillation).
BigBad
Thu Dec 03 2015, 05:51PM
Signification wrote ...
Yes, you can get very high efficiency.
In fact there's a name for this device, and there's probably several in your house right now: switch mode power supply wink
If you think about it, in a switch mode power supply after the rectifier there's a capacitor on the input and there a capacitor on the output, and the charge goes from one... to the other.
DerAlbi
Thu Dec 03 2015, 06:22PM
No no no nooooh smile In an insulated power supply the charge does not really "go" from one to the other due to the lack of a path wink
BigBad metapher tongue
Bored Chemist
Thu Dec 03 2015, 09:25PM
DerAlbi wrote ...
I can do a theoretical simulation with no series resistance and no problem at all.
The current never gets infinite.
I just add an inductor to the system.
BigBad
Thu Dec 03 2015, 09:36PM
DerAlbi wrote ...
Not all switch mode power supplies are isolated. Check out buck converters and boost converters.
DerAlbi
Thu Dec 03 2015, 10:52PM
Bored Chemist: what simulation?? Does the current not go to infinite without the inductor? Or do you add the inductor to make the simulation run??
Very confusing statement. Are you just troling? cheesey I mean.. we all know that simlation programs have mechanism in place to resolve such situations. (like default ESR in LTSpice or a finite minimal time step)
BigBad
Fri Dec 04 2015, 12:24AM
DerAlbi wrote ...
Electrons are indistinguishable at the quantum mechanical level anyway tongue
Electrons can quantum tunnel, swap over, and quantum tunnel back and you never know they've done it... and they actually do this.
DerAlbi
Fri Dec 04 2015, 11:12AM
Ahahahaaa BigBad i hit a nerve. cheesey Dont bother, i was just trolling.. No need to defend yourself. It was a good example, no worries.. but this obvious flaw.. excuse me, i couldnt hold back shades
What would be really mean at this point would be mentioning that charge pumps can have a near 100%-efficiency with resistive switches only. amazed
Now your minds boggle! amazed
