  • Guests: 27
12/13 williamn (48)
12/13 ReddyK (57)
12/13 Birdman (31)
Yeeeeha! Microprocessor controlled induction heater
1 2 3 4  last
Mon Mar 15 2010, 01:57AM Print
I have successfully made a microprocessor controlled induction heater. My goal was to have a unit that will locate, lock and track resonance without any user input, and with any coil or workpiece.
The video shows how accurately and cleanly the circuit holds onto the resonant frequency. The range is 50 khz - 100 khz, but I can set it to anything. However, I have finer resolution if I keep the range tighter. Right now I can move in 12 Hz increments.
My next step is to connect it to 220v mains and see how hot I can get things. Then, I want to try and levitate a solid piece of steel and copper.
Bjørn
Mon Mar 15 2010, 04:01AM
That is excellent, it seems to work perfectly. Don't forget to explain how you did it.
Mon Mar 15 2010, 04:04AM
I plan to post schematics and have an updated video when I get it set up.
Mon Mar 15 2010, 08:21AM
nice! :)
something like this would be handy for a reprap liquid metal dispensing nozzle...
-A
Mon Mar 15 2010, 01:01PM
Neat! Was this more enjoyable to design than the analog induction heater? I've never given digital control loops much thought, but there's so much more you can do with them that they must really excel in applications like this. What kind of microprocessor are you using?
Mon Mar 15 2010, 01:21PM
ATMega328
GeordieBoy
Mon Mar 15 2010, 02:39PM
Cool. What did you use for the RF source driving the inverter? Direct PWM out of the micro at the IH frequency, an analogue VCO controlled by the micro, or a digital DDS chip?
Have you implemented current/voltage limiting in your software controller also? You don't always want the inverter to pump full power into the tank circuit at it's resonant frequency. A typical example of this situation would be if the workpiece is removed.
-Richie,
Mon Mar 15 2010, 05:49PM
Well. I have a small setback. It seems that as I increase the input voltage at resonance the chip gets reset. It just stops. The only way I can recover is if I take the microprocessor out and reprogram it.
Any thoughts? Do I need to tie all inputs that aren't being used to ground? Do I need an optocoupler to isolate my pwm output to the opamp? More decoupling capacitors somewhere?
Nicko
Mon Mar 15 2010, 06:06PM
IamSmooth wrote ...
More than decoupling I would have thought - have you scoped the power lines for the uP? also, with all that RFI, tie everything down to GND that's unused (nothing floating) anywhere, and screen & filter like crazy. One thing I learnt early was to use a completely separate regulator & filtering for the uP - don't share it with anything else! You can make nice boxes with FR4 board soldered up - a common radio amateur trick - e.g. see Link2 and Link2 etc.
I use the ATmega168PA at lot (will be using the 328 as they are essentially the same chip) with a TC for something I'm, working on, and I'm probably going to optically isolate all my I/O so that the uP can live safely in what is an extremely non-uP-friendly environment...
Another thought: Check your ground path and make sure nothing else is returning current anywhere near your uP - use a "star ground" configuration.
cjk2
Mon Mar 15 2010, 09:54PM
Could it be something as simple as a signal coupling back to the reset pin on the Atmega? Use a pullup resistor on the reset pin and see if the problem goes away.
1 2 3 4  last
