  • Guests: 26
visible UV-triggered particle emission demonstration
Signification
Sat Jul 11 2015, 11:54AM Print
Does anyone know of a simple way to use readily available parts (ebay, etc.) to actually construct a photoelectric type apparatus that makes visible, a photo-emission of electrons? I am not speaking of an actual triggered spark gap, OR of the common demos with an electroscope, but a way to actually see an electrical 'corona' type discharge initiated by a light source striking the metal. Perhaps a blue ray frequency UV laser diode (I know this is 405nm which may not be energetic enough) or focused UVC anti-bacterial lamp striking a low work function metal (polished zinc??) If a pressure lower than atmospheric is required, then it should be easily obtainable with a hand pump or standard (high-school physics) type vacuum pump.
Sat Jul 11 2015, 12:58PM
I think that an activated Zinc Sulfide screen would work,
there are sellers on eBay, e.g. Link2
or you could scrape the 'phosphor' from inside a fluorescent tube or c.r.t. from t.v. or monitor.
Signification
Sat Jul 11 2015, 02:02PM
Sulaiman wrote ...
Thanks, I ordered one for several uses I would have from the ebay description. Eventually, I would like to get an ionized region around the emitted particles--to actually make and demonstrate a UV-generated conductive region through the emissions. Finally through, I guess I am actually looking for a UV triggered SG, just to see the principle in application
