  • Guests: 48
High Voltage, High Power Resistors.
Mon Jul 13 2015, 10:02PM Print
Im looking for a high voltage resistor with some requirements to follow.
5 to 10kv @ 0.004 A
1.25 Mohms
20 watts.
i effectivly want a load resistor to keep the "real HV present" and the bogus short duration peaks out.
is there anyway to make our own ? does nichrome wire still work if the voltage gradient is low enough ?
Antonio
Mon Jul 13 2015, 10:56PM
Many resistors in series. But I would prefer redesigning the system to not waste all this power.
Mon Jul 13 2015, 10:57PM
Antonio wrote ...
I need to temporarily waste this power as heat, for measurement purposes. the final device wont waste much power at all.
edit: thats alot in series and paralellel.
Signification
Tue Jul 14 2015, 12:00AM
Patrick wrote ...
5 to 10kv @ 0.004 A
1.25 Mohms
20 watts.
Maybe five 250Kohm in series (4W ea. for "watts only")...but larger (25W ea.?) for 1kV ea. Perhaps in oil or Si for 2kV ea?
I DON'T think secondary's of:
NST's
Ignition coils
Flybacks, etc.
makes the "R",
But,
ebay sells very cheap (few dollars) potted HV modules (IIRC around 700,000V out!). I do not know the secondary characteristics.
Tue Jul 14 2015, 12:01AM
Yes, what Antonio said.
Set up a spreadsheet calculator program and start shopping, perhaps on ebay.
To dissipate 20 watts with passive cooling & no heatsink attachment, the dummy load has to be spread out a bit.
Even more so if you need an 80 watt load (10 kV, 1.25 mΩ).
Here is one example on ebay now:
51000 ohm / 51K - 1 watt 1W - 5% - Carbon Film Resistors (8 Pieces) $3.10
24 of those in series would make a nominal 1.22 MΩ 24 W resistor bank.
5000 volts would give you 4.08 mA, 208 volts per resistor, 0.85 watts per resistor.
Plenty of margin on V rating for this resistor package style & size.
Slim margin on power rating, but the R's can be mounted close together if there's free air circulation between them.
To save soldering, you could look for high voltage (and higher power) resistors.
10 Ohmite Slim-Mox 108 2M 2.5W 10% TF Planar Resistors US $12.99
Ash Small
Tue Jul 14 2015, 12:03AM
Suppressed auto ignition cable (the cheap stuff) will take the voltage. I'm guessing four or five feet might get you 1.25Mohms, from past experience. That's not a lot of amps, so it might be worth a go, especially if you can get it cheap, or free.
Electra
Tue Jul 14 2015, 12:12AM
Well you can't always get it spot on, but 32 x 39k = 1.248 M ohm. For 10kv that's about 321.5v each. You can get 350v resistors in 2 w . So they shouldn't run really hot.
Of course you can get high voltage resistors, but they tend to be expensive and don't come in a huge range of values.
(Edit)
Just comparing results with Klugesmith's I didn't check 10kv is yes 80w so you may need more than 2w resistors if operating constantly
Tue Jul 14 2015, 12:55AM
it only need to operate at 5 intervals. and itll be under oil.
Tue Jul 14 2015, 02:56AM
You might get lucky at a swap meet. These guys are 100K (total 1 Meg) and the whole lot was $10.
1436841748 2099 FT172149 Dscn9547
I just learned something from Electra. Had thought that 350 V spec was usual in 1/2 watt axial-leaded resistors, and that 1 watt size were normally 500 V. Here's a counterexample. Panasonic ERX series 1/2 watters are 300 V. 1, 2, and 3 W sizes are good for 350 V. Not until 5 watts does the continuous "limiting element voltage" reach 500 V. See page 2 of: Link2
One way or another, your load gets 20 watts (or 80 watts) and its internal temperature is what counts.
Rated power can be exceeded substantially (see datasheets) for a few seconds, if the R's are initially not very hot.
It can be exceeded for longer in oil, until the oil itself gets too hot.
IMHO, neither short duty cycle nor oil will protect your R's from morbidly excessive _voltage_ per resistor.
Tue Jul 14 2015, 03:06AM
yes the more i calculate, the more heat-per-resistor seems to be the greater limiting factor than the voltage-per-resistor.
