  • Guests: 32
switching multiple elements
kell
Mon Oct 16 2006, 08:38PM Print
kell Registered Member #142 Joined: Sat Feb 11 2006, 01:19PM
a through e are various solenoid valves and pumps that I have to turn on and off.
I have to switch the system between three states, as indicated in the table below.
a       b      c      d       e
                     doesn't
1    off     on     matter   on     off
2    on      off     on     off      on
3    off     off     off     on      on
Should I try to do this with switches and relays, or go solid state?
It is a twelve volt system. The solenoid valves (a b and c) draw less than an amp each. Haven't measured the draw of the pumps (d and e), but say three amps each.
The solenoids have grounded body and must be switched from the positive supply.
The pumps each have plastic body with two wires.
Mon Oct 16 2006, 10:18PM
You could do it with 3 double pole single (or double) throw relays (or if it comes to it, you could use 6 single throw ones) connected such that:
1st relay... pole one goes from +v to B, pole 2 goes from +v to d
2nd relay... pole one goes to a, pole 2 to a and c, pole 2 goes to e
3rd relay... pole 1 goes to d, pole 2 to e
3a dpst relays are pretty cheep, so I would use use those.
Tue Oct 17 2006, 02:52AM
Notice that A and C can be the same
so
A 4-pole 3-way switch is all that's needed.
If you can't get a high current switch then add four relays
Don't forget to put four suitable capacitors across the four switches to reduce contact wear
or across the four sets of relay contacts.
May be worth adding four lamps (led or filament) to see the status.
(Monitor for burnt-open or welded-closed contacts)
kell
Tue Oct 17 2006, 06:17PM
To do this witha single switch it looks like a rotary switch is the best bet. Finding a piece of junk equipment with a three or four pole switch would be the shiznit but I may end up having to order one.
Edit:
I just thought I'd mention a single pole triple-throw switch will do it. Just have to use diodes in the lines to keep the power from backfeeding through the interconnections.
