  • Guests: 46
questions about a series resonant IH
Fractal Universe
Thu May 07 2015, 05:47PM Print
Fractal Universe Registered Member #4349 Joined: Wed Jan 18 2012, 01:23AM
after experimenting with a Royer IH i built some time ago, I am convinced that the royer circuit is not sufficient for delivering enough power to be a useful tool, nor is it reliable enough, and it runs on an odd power supply (36v batteries, right off the wall socket would be much more convenient). so i've decided to try to build a manually tuned TCSR setup similar to Bwang's setup, but using a mosfet 1/2Hbridge similar to Uzzor's setup instead of IGBT's
i plan on powering it off of a 120 vac 60Hz 20A receptacle
the parts i plan to use:
FETs: infineon 47n60cfd driven via GDT
freewheel diodes:RHRG1560
series schottky diodes : MBR4045
Tank cap: eurofarad snubber 3.1 microfarad @600vrms, 152 Arms
oscillator: SG3525 directly driving 2 IRFz44r which will drive the GDT via push-pull from a 15v supply
20a fuse for protection
is there anything i am missing here?
Thu May 07 2015, 09:51PM
mister_rf Registered Member #4465 Joined: Wed Apr 18 2012, 08:37AM
Yes. shades
There are many things IMO, but let’s start by as asking one thing: do you have any schematics as a guideline for this project?
