  • Guests: 43
Hanzie (31)
badger (52)
h3X (40)
01/12 RoV IW3IPD (63)
Heating on half bridge
furnace
Sun Apr 12 2015, 06:12AM Print
furnace Registered Member #4992 Joined: Wed May 23 2012, 03:57PM
What could cause my low side mosfet to get hot if my signal is perfect and in phase?
I've tried adjusting the timing but it just does not make any difference.
dexter
Sun Apr 12 2015, 10:06AM
you need to give more details like a schematic and some pictures
furnace
Sun Apr 12 2015, 10:21AM
This is the signal of low side mosfet and the sine wave is my tank signal which is the feedback to my pll.
1428834064 4992 FT170508 Pure Wave
1428834065 4992 FT170508 Inductionschematic
johnf
Sun Apr 12 2015, 07:48PM
Furnace
I do not like d5 d6 in your schematic this is taking 5.1 volts off your gate drive . Also there is no load on the gates so the gate capacitance will make the gate slow to switch off =heat.
Check other circuit sources especially data sheets for your driver ic's for the correct gate drive circuitry
furnace
Mon Apr 13 2015, 01:24AM
I did try and remove d5 and d6, but it makes no difference, they actually work good because it gives me timing delay.
I don't understand what you mean by not having load on the gate?
Do I need to add something extra on the gates?
johnf
Mon Apr 13 2015, 10:07AM
Furnace
I would expect 10K or lower to local earth (ie source) from gate to stop it floating around due to dVdt and the internal capacitance of the switching device
furnace
Mon Apr 13 2015, 03:46PM
Connected a 5k, now switches heat up more evenly.
Are my switches suppose to heat up? Or could this also be a sign that my ferrite core is saturated? I have a large u core OP49925UC.
When I go past currie point my switches heat up aggressively and blow up. Should I move to larger switches or could it be my core and is there a way to test for core saturation?
TwirlyWhirly555
Mon Apr 13 2015, 04:10PM
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Where have you placed the 5K resistors ?
The only resistors you should have in the gate circuit is the 3.3 Ohm ones in the diagram .
furnace
Mon Apr 13 2015, 04:26PM
I placed it on the gate and Source in parallel. Is this wrong?
