  • Guests: 50
Ben7 (29)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
Fan motor re-oiling?
Tue Mar 17 2015, 09:43PM Print
This is about porous bronze bushings surrounded by felt oil wick.
Mine are in a kitchen exhaust fan motor, too neglected & gummed up to start.
Here it is after being cleaned inside and out.
1426628454 2099 FT0 Fan1
The tail-end bearing cover is completely closed on the outside, and looks sort of like this stock picture on the inside:
1426628454 2099 FT0 Fan2
After the bearing areas were soaked in WD-40, the shaft spins freely. But compressed air applied around the bushing produced not a single bubble at the flared ends of oiler tubes. And WD-40 is not a motor lubricant.
Any hints on how to clear the tubes and/or remove the WD-40 from felt, before re-oiling?
I'm about to learn how much a replacement motor (probably with inferior bearings) costs over the counter.
A whole new exhaust fan (with inferior, open-frame shaded pole motor) is only $80 at regular hardware store.
BigBad
Wed Mar 18 2015, 02:12AM
Soak it in petrol maybe? Not sure.
Wed Mar 18 2015, 06:22AM
on my CNC milling machine, i had a bearing that couldnt be replaced, and so had to be cleaned out. i used a plastic, sort of deformable funnel from the kitchen. made it fit the round face of one side of the bearing. i sealed the other end, and put a bearing nipple some where on the funnel, then a grease gun pushed in some white lithium grease, to the point it was bursting out the other side quite vigorously. you need a seal, but it doesnt need to be perfect.
id use a small funnel, or simialar piece of plastic, as you dont want to push half a tube of grease into a tiny bearing. in your case maybe a rubber automotive hose cinched shut at one end.
not sure if you plan for grease of heavy weight oil.
or 80 $....
Ash Small
Wed Mar 18 2015, 09:37AM
I don't think it's worth soaking in a solvent, then waiting for the solvent to evaporate.
I'd just get as much oil in there as possible. Any WD40 in there will thin the oil and allow it to penetrate better. The WD40 will partially evaporate anyway. Just re-oil it again in the not too distant future. Semi-regular maintenance/oiling is what's required here wink
johnf
Wed Mar 18 2015, 06:56PM
I dont know where yesterdays reply went
sintered bearings are cleaned with a good degreaser such as methylene chloride (di-chloromethane) or Di-ethyl ether reoiling requires the shaft to be out . You block the bottom hole with one finger and fill with a good light oil Mobil 1 0-W50 and press another finger on the top. this forces the oil into the sinter. All old motor mechanics knew this for starter motor bushes and flywheel clutch pinion bushes
Wed Mar 18 2015, 07:25PM
Yay! methylene chloride. Everybody's favorite chloride. smile
Thu Mar 19 2015, 06:56PM
Thanks for l the suggestions, esp. johnf with how to make oil pressure with fingertips. The dialog confirmed link with same individual on another forum, so it was no surprise to learn that Lower Hutt is in NZ. smile
The form factor has been popular since before the rise of Nazi party. I found a substitute motor new, over the counter, for under $40 including tax. New one has case 1/2 inch longer. Dealer had one matching the original case length, but we plugged it into check rotation direction & it was wrong.
radiotech
Sat Mar 21 2015, 03:00AM
Sometimes the direction can can be reversed by' transiting' the stator. That is
turning it upside down if mechanically possible.
Now is also the time to go over all the grease laden nooks and wireways and
renew them right back to the outlet box.
Ash Small
Sat Mar 21 2015, 12:08PM
John Futter is correct. I thought you wanted to re-oil it without stripping/cleaning etc.
