  • Guests: 51
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
12/18 LD LANGER (38)
Reverse engineer of PTB48560B 30W DC-DC isolated converter in order to change its output voltage.
Wed Mar 25 2015, 11:50AM Print
mister_rf Registered Member #4465 Joined: Wed Apr 18 2012, 08:37AM
The PTB48560x is a series of 30-W rated isolated DC/DC converters, designed to operate from a standard 48Vdc telecom supply. This model (PTB48560B) has a adjust output voltage that can be set to intermediate bus voltages of 1.8 - 3.3 V.
The input Voltage: 36 V to 75 V
30-W Total Output Power
Output Voltage: 1.8V up to 3.3 V
Up To 88% Efficiency
Overcurrent Protection
I was quite lucky to find those converters on sales, at 4 euro per item.
The major problem I ran into was the board is a 4-layer with lots of tiny traces. The trick was to get the circuit diagram of the DC_DC supply and based on that diagram to hack the PCB to get the desired output voltage.
I took pictures o the front and bottom traces of the PCB.
1427283060 4465 FT1630 Ptb48560 Converter Pcb
The primary side integrated circuits marking: 257021, L393, T1IG, E: A, HHS3.
Discrete semiconductors: 7464, KJC, Y2W, KJG, KJC, KJG, YJ03
Optocoupler: 8101
Secondary side ICs: T1IG, RLB, VBGI, T1IG,
Discrete semiconductors: S15L30C, S15L30C, B4H, W2X, 4NCU, 8k, 7840, Y2W, W5C, 702, 702, Y2W
L393= LM393
257021=UCC25702 Advanced Voltage Mode Pulse Width Modulator IC
T1IG= TL331IDBVRG4 SINGLE DIFFERENTIAL COMPARATOR
8101= MOC8101
VBGI= TLV2371ID single supply operational amplifier
Y2W= BZX84-C12 Voltage regulator diode
7464= Si7464DP N-Channel 200-V Fast Switching MOSFET
7840= SI7840DP N-Channel 30-V Fast Switching MOSFET
S15L30C= STPS15L30CDJF Low drop power Schottky rectifier
B4H= Low drop power Schottky rectifier diode
W2X=PMBT4401 NPN Switching Transistor 40 V 600 mA
4NCU= LM4040C50IDBZR 5V Precision Micropower Shunt Voltage Reference
8K= N channel MOSFET transistor
KJC= BAW56W DUAL SURFACE MOUNT SWITCHING DIODE
KJG= BAV99W DUAL SURFACE MOUNT SWITCHING DIODE
W5C = PMBD7000 two high-speed switching diodes
YJ03= NPN bipolar transistor
702= 2N7002 N-channel Trench MOSFET 60 V, 300 mA
E:A= ? (That’s seems to be some kind of under/overvoltage safety circuit)
HHS3= ADT6501-ADT6504 ? Micropower Temperature Switches
RLB= ? 3-terminal adjustable shunt regulator
1427283163 4465 FT1630 Ptb48560 Dc Dc Converter 2
So, in order to lower the input voltage, all that's needed is to change R11 or add another resistor in parallel, and the 91k up to 100k resistor will do the trick. For this setup the minimum input voltage is about 20Vdc.
1427283060 4465 FT1630 Ptb48560 Prototype
To adjust the output voltage we need to add supplementary turns to the secondary transformer and a new resistor R51. At 5V one turn is necessary and for 12V 4 to 5 turns to be added. The value for 5Vdc output R51= 31.5k and for 12Vdc output the resistor value R51= 5.3k.
For the 12Vdc output, in order to minimize power wasted in PCB, we need also to change the R25 and R46 and to take out the R33.
1427283060 4465 FT1630 Ptb48560 5v Modified Transformer
See the final hacked version of the PCBs:
1427283060 4465 FT1630 Ptb48560 12vmodified
1427283060 4465 FT1630 Ptb48560 5v Prototype
I have done tests on 12Vdc output using a 10 ohms load. At this power level some of the PCB components temperature reaches up to 90°C. See the attached thermal pictures of the board at start-up and later on, after 15 minutes on a 10 ohms load.
1427283060 4465 FT1630 Ptb48560 Temp
1427298877 4465 FT1630 Ptb48560 Thermic
The wide output voltage adjust range and the wide input voltage range makes the PTB48560 series of converters an attractive product as a stand-alone dc/dc converter. Now the output voltage can be adjusted to any value within the applicable adjust range. In this case the Auto-Track features are simply not used.
Final products:
1427283060 4465 FT1630 Ptb48560 Pcb Front
