  • Guests: 33
Arc welder as a amp source
Andy
Wed Feb 25 2015, 05:20AM Print
Been looking around for high amp sources and I have a arc welder, which they can be picked up quite cheaply.
What would the effect of running this throught a large copper cable, with theac changed to a bridge, would it have any negtive effects on the welder been a short, would the voltage stay at around 20-40 volt or drop sshorted throught a copper wire.
Any ideas that might effect it that I havnt thought of, welcomed
Cheers
Shrad
Wed Feb 25 2015, 06:40AM
drop, heat, thermal fuse come into my mind
I'd parallel a bunch of 12V 50A server power supplies as they are spec'ed not to sag at the maximum current
dexter
Wed Feb 25 2015, 11:21AM
you have to apply Ohm law....
in a short circuit case or for a very small resistance for a REAL power source the voltage will always drop to about 0V and the current will be maximum
Shrad
Wed Feb 25 2015, 01:24PM
correct, but an AC arc welder will not necessarily be current limited, while a good SMPS with built in limiting and conservative ratings will deliver all those amps without burning after a couple minutes
you could always use rewound MOTs and a kind of phase angle switching to limit current
dexter
Wed Feb 25 2015, 02:36PM
Shrad wrote ...
yes it can deliver all those amps but the voltage will in no way be the same as the rated supply voltage....
in the case of a server psu yes it can deliver 70A and keep the voltage constant but only to a proper load
if a short occurs the psu can't deliver 70A while keeping the voltage constant (again Ohm law) and it will stop
Andy
Wed Feb 25 2015, 03:10PM
If I keep the resistance so the short is 5 amp less than the max setting, it should work, is that what you two are saying?
Shrad
Wed Feb 25 2015, 05:28PM
if you use a simple transformer without current limit, it will overheat
if you use a SMPS within its ratings you should be able to get big current as soon as your load impedance is not too small and resembles that of a server
dexter
Wed Feb 25 2015, 05:35PM
Andy wrote ...
in that case there is no short you will be just near the max power capability so no voltage drop and no psu failure
Ash Small
Wed Feb 25 2015, 10:46PM
All AC arc welders I've seen are current limited. Thet need to be, they drive what is effectively a 'dead short'.
I've used AC arc welders to drive stuff like electrolysis tanks, using a big rectifier.
Electra
Thu Feb 26 2015, 10:35PM
Consumer grade arc welders, I don't think are rated for 100% continuous operation. They expect time to cool down between welds. So you would have to de-rate them.
The voltage regulation probably wouldn't be that good. They may be 50v on low load and drop to half that on full load.
Good thing is they probably will stand a lot of abuse, And yes be short circuit proof for a short duration, until a thermal cutout kicks in.
Not sure if I've understood correctly but if you are just trying to power a large coil of wire, like an inductor or electromagnet, You only need enough voltage to overcome the d.c resistance of the coil to generate the current you require, plus what you drop across the rectifiers.
