  • Guests: 39
Poineer IP BUS pinout
Ash Small
Fri Jan 30 2015, 10:44PM Print
I found this on another forum and thought I'd re-post it here. Do we already have a thread for this type of thing?
The diagram is pretty self explanatory, and shows right and left audio channels.
I needed it to connect a Pioneer bluetooth tranceiver unit to my audio system via RCA connectors.
(This is for IP BUS out, the Black end of the lead. I'm not sure if IP BUS in, the blue end is the same or not. Maybe someone here knows?)
EDIT: found the blue end pinout, I'll post it here.
JUST TO CLARIFY, THESE ARE LOOKING AT THE SOCKET, NOT LOOKING AT THE END OF THE LEAD ITSELF
Apparently the easiest way to 'hack' these is to use bits of old Molex connectors from old PC's.
1422658809 3414 FT1630 Pioneer Head Unit Aux Pinouts
I've not actually wired mine up yet, I need to find a suitable 12V 200mA power supply. Hoping to get it sorted this weekend though.
Ash Small
Fri Feb 27 2015, 11:56PM
I wired it up to a 13.2V supply, but can't get my phone to 'see' it, so I presume it's dead.
I checked the supply with a 2.2W 12V bulb and DMM to determine polarity and voltage at 200mA.
