  • Guests: 35
Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
12/18 LD LANGER (38)
Electrical breakdown of air vs. disintegration of asphalt
Tue Feb 24 2015, 12:47PM Print
Each day on my way to work, I ride my bicycle on cycle tracks and lanes, some of them have some damages that reminds me very much of how spark formation takes places as the air breaks down.
So I have been thinking about how electricity takes the path of least resistance and how it looks like the asphalt disintegrates in a similar way, where the path is weakest, so a crack forms where there is least resistance.
Just a thought I want to share :)
1424782221 1403 FT169327 Imag0439
1424782221 1403 FT169327 Imag0440
1424782221 1403 FT169327 Imag0441
Dr. Slack
Tue Feb 24 2015, 01:02PM
The thing that links those materials is the positive feedback nature of damage to their integrity decreasing their ability to resist further damage. Thus arcs follow ionised paths through air, water/frost/movement damage occurs preferentially in cracks in asphalt.
Both also suffer crack propagation, where the damage concentrates the stress, tending to make exsiting damage grow.
The opposite thing happens in a polypropylene flexure, where you have work toughening.
From those photos though, I might suspect that that there is a problem with the substrate below the cracks, and it's not simply random failures propagating.
Tue Feb 24 2015, 09:29PM
Thanks for sharing!
Reminds me of the almost electrical speed at which cracks can propagate in glass.
Especially tempered glass, for example "Prince Rupert's drops".
Recently stumbled on this video:
radiotech
Sun Mar 01 2015, 02:08AM
Assuming the asphalt is homogeneous then an alternate hypothesis could
be the pathway is being subjected to a longitudinal heave wave, thermal, hydrostatic,
or seismic , and the damage areas represent sharp disturbances in that velocity.
Asphalt de Broglie waves?
Wolfram
Fri Mar 27 2015, 09:15AM
I got some very interesting fractal-like patterns when overheating steel sheet with an induction heater at 300kHz. An overheated zone forms near the edge of the sheet, and it propagates through the material due to the higher resistance (and therefore higher dissipation) in the overheated zone.
1427447742 33 FT169327 Induction Fractal
