  • Guests: 33
Mains Conn cted capacitor voltage divider driven a load
Andy
Tue Jan 13 2015, 06:55AM Print
Hi, I,ve built the below circuit hoping that I could get 120,4 volt,amp throught a 14.5 ohm load, but nothing seems to get produced
Ideas?
1421132110 4266 FT0 Img 20150113 195253
Tue Jan 13 2015, 08:51AM
Imagine the 240 Vrms with two 60uF capacitors as
120 Vrms with 120 uF in series.
So the circuit becomes
120 Vac - capacitor - diode(s) - resistor - Neutral
Think of it as
Neutral - Resistor - Diode(s) - capacitor - 120 Vac
a typical half-wave rectifier charging a capacitor
The capacitor will charge to almost 170 Vdc then no more current will flow.
there will briefly be voltage across the resistor as the capacitor(s) charge, then no more.
The actual voltage at the junction of the capacitors will be 120 Vrms with a -170 Vdc offset
On a 'scope that would look like a sinewave with the positive peaks just above 0 V
(due to the diode(s) drop )
To make it work you need a full-wave (bridge) rectifier on the output of the capacitors.
Blackcurrant
Wed Jan 14 2015, 12:24AM
Hi Andy
I would use a quick spice simulation
like
it will give you an idea of power in things etc
Andy
Thu Jan 15 2015, 07:17AM
Thanks Sulaiman, im still learning to fish :).
Thanks Blackcurrent I took your advice and simulated.
Cheers
