  • Guests: 49
inductance derivation
Tue Oct 03 2006, 02:07AM Print
I have searched google but can not find the derivation. I know how to derive the inductance for a solenoid, but does anyone have a link or reference where I can see the derivation for inductance of a flat spiral based on its geometry (inner radius, outer radius, turns)?
Tue Oct 03 2006, 02:30AM
First, the derivation of inductance for a solenoid applies to 'infinitely long' solenoids
Mr. Wheeler did lots of measurements to arrive at the empirical equation that we commonly use.
For arbitary solenoid dimensions I'm not aware of a simple explicit derivation,
any references?
Similarly for a spiral coil the equation is also I believe empirically derived.
Tue Oct 03 2006, 03:05AM
Here is the derivation for a solenoid Link2
WaveRider
Tue Oct 03 2006, 09:12AM
That is for an idealised long solenoid.
Derivations for realistic coils is difficult, but possible if certain assumptions are made (e.g. the conductors are infinitely thin). Numerical methods are needed for "real" coils..or approximations (like Wheeler's formula).
I have attached a few pages of S. Ramo, J. R. Whinnery and T. Van Duzer, Fields and Waves in Communication Electronics, Second Edition, 1984. These pages give some of the mathematical background if you want to develop your own software to compute inductance of real coils....(which in reality, would not be too difficult to do if you are familiar with some basic numerical methods). Have fun!
1159866483 29 FT1630 Inductance0001
1159866483 29 FT1630 Inductance0002
1159866483 29 FT1630 Inductance0003
1159866483 29 FT1630 Inductance0004
Dr. Slack
Tue Oct 03 2006, 12:45PM
Wheeler and versions thereof are good for giving a few percent accuracy for many coil geometries. However, you can get surprisingly good estimates from very gross approximations to the coil shape, if you are happy with 10-20% accuracy and a feel for what is going on.
1) Estimate the path of the 'average' field line.
2) Its distance from the average conductor gives the H field for unit current in the coil
3) The H field and the line length give the mean B field
4) The average conductor area and the B field gives the flux linakge per unit current, which is the definition of the Henry!
If the air path is replaced by ferrite or iron, then the above method becomes extremely accurate, the estimates replaced by measurements of the actual core.
If the air coil is very extended, like a Tesla primary, or secondary, then the estimates become very flaky indeed, but it's still worth doing a) to get a physical feel for what is really going on and b) to make sure your Wheeler calculation isn't out by a factor of 10, or 25.4, or something silly.
For a compact "max inductance per length of wire" geometry winding, I got to within 3% of Wheeler with my approximation, your hand-waving may vary!
