  • Guests: 51
muller (38)
Dr. Mario (38)
Ben Solon (30)
01/28 LTX (57)
01/29 IAmSpock (18)
01/30 Ian (37)
Looking for expert about PL fluorescent lamps
Mon Nov 17 2014, 02:51AM Print
This is about an early style of compact fluorescent lamp ("bulb"), the PL, which has two or four pins and plugs straight into a socket. The magnetic or electronic ballast is part of the fixture, not the lamp.
1416190798 2099 FT0 G24q1
(LOL. Our 4hv image thumbnailer seems to care about width but not height.)
The q-1,q-2,q-3 mechanical keying indicates the design wattage. In a lampholder catalog I found an unkeyed socket option. smile
I want to test a 13W lamp on the bench, for want of a known-good fixture. It's got a G24q-1 base, which is one of the least unpopular kinds in the USA. Might we expect the 4-pin PL to be electrically similar to a straight T5 lamp? I'd like to try it with a primitive 2-wire ballast and manual-start switch, as found in a handy EEPROM eraser. Link2
Curiously, I _do_ have a fixture for a 2-pin PL lamp. In series with the lamp socket is a simple choke which says "OCF-79 FOR 7-9W LAMP. 118 V 60 Hz." I bet the lamps have an old-fashioned bimetal starter tube built into the base.
Shrad
Mon Nov 17 2014, 09:55AM
I have some money tester lamps which have the same pinout, and found them to be TL equivalent with two filaments (one each end) for 4 pin tubes by testing with a conductivity tester
this suggests that they have filaments as any TL : Link2
