  • Guests: 67
Controller IC with fixed on-time, variable frequency
Tue Oct 21 2014, 11:04AM Print
Hey all,
When building my SLR inverter I found the need for a dedicated controller IC which could provide a programmable, constant on-time, and variable drive frequency based on the load. This could be mixed together using some discrete-ICs, but I was wondering if anyone knew of or was familiar with any chips which did this already. Constant duty cycle won't cut it, because the on-time cannot exceed a certain limit in seconds. I've found some resonant-mode controllers, but they feature constant deadtime instead.
dexter
Tue Oct 21 2014, 11:53AM
Check this link Link2
is a integrated half bridge and controller from Fairchild
Tue Oct 21 2014, 12:19PM
a 555 in normal astable mode gives fixed on time (low) and variable off time (high)
any monostable triggered by a variable frequency gives a fixed on time, variable off time / period / frequency
