  • Guests: 46
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Cell phone charging (homemade chargers)
kimbomba
Sun Oct 12 2014, 03:01AM Print
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
Have anyone seen those homemade portable cell phone chargers that are nothing more than 4 NiMh batteries in series and a switch?, they should give about 5 volts, which is the correct voltage but i am not sure if they are safe to use. Others use a 9V battery and a 5 volt regulator. Do cell phones have internal circuitry to limit the charging current or they rely on the charger to do that? Thanks in advance
Sun Oct 12 2014, 07:34AM
Wikipedia Link2
So the device plugged into a usb port must control it's current draw.
Which means you can just have 4z Ni-Vd in series as a usb power source
but you should put a fuse in series with the cells to protect the battery in case of short circuits.
I'd prefer 2x Lithium and an ldo regulator because
here in Europe the use of environmentally unfriendly Cadmium has been phased out
it is a voltage-regulated current-limited output
Ash Small
Sun Oct 12 2014, 02:18PM
You can use a resistor to limit max current, and use series diodes to limit max voltage, due to forward voltage drop of the diodes.
Other, higher tech, solutions are available, though, using current controllers, etc.
Sigurthr
Mon Oct 13 2014, 02:09AM
I've done it a few times. I just use paralleled 7805s or appropriate LDO regulators. Sulaiman nailed it; voltage regulated, current limited supply. 5V +-20mV @ 500mA - 4A. Certain devices won't charge with less than 500mA, and some devices want to draw up to 2.1A (usually tablets).
Mon Oct 13 2014, 07:00PM
but if they invlove a battery and a linear regulator like a 7805, any input voltage over the 5 volt output is wasted as heat. (times current)
Mon Oct 13 2014, 10:52PM
You can have a buck converter, sepic etc.
but as a simple project an ldo linear regulator is simpler,
and the voltage regulation and current limiting is worth the losses.
(compared to a battery fire !)
The loss of power as volts x amps is a concern ... dispersing the heat from the regulator
but the mA.h will be the same as the battery pack,
and a LiPo pack has more mA.h per volume or weight than NiCd.
Tue Oct 14 2014, 02:52AM
yes but LiPo's are sensitive to discharge.
