  • Guests: 40
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
TO-247 Insulating pads
Sun Aug 17 2014, 12:54PM Print
Hey everyone,
Im currently working on a driver for some transformers, i need a decent quantity of TO-247 Insulating pads, with screws.
is there anywhere to get them at a decent price? some places like farnell seem to be charging aweful prices ( £1 each????)
I can find TO-220 ones much cheaper and very common, but the TO-247s for some reason are not.....
thanks,
TCW
Sun Aug 17 2014, 01:20PM
eBay is much cheaper, e.g. Link2
You can buy a silicone sheet and cut your own, but good sheet is also expensive,
or you can use Mylar, polyimide or similar self-adhesive tape which works well and is cheaper.
Sun Aug 17 2014, 01:30PM
Sulaiman wrote ...
or you can use Mylar, polyamide or similar self-adhesive tape which works well and is cheaper.
Thanks Sulaiman, hadn't seen those.
By the way, does anyone know the max speed in kHz of CM300DY-24NF IGBT bricks?
im working on a driver for a 3kW Transformer that requires mains @ 60kHz.
also working on a driver for 6 of them (18kW) requiring the same frequency of 60kHz.
Thanks,
Thomas
Fri Sept 05 2014, 08:34PM
Be sure to check the thermal resistance/conductance of the material. Some silicone-based insulators can severely cripple thermal performance.
I found 1 mil kapton to be the best answer for my isolation needs. For a TO-247 it adds about 0.5*C/W thermal resistance. Mica is usually thicker so it adds more resistance despite having better conductance. I haven't found a silicone type pad that even comes close to the performance of the 1mil kapton. The best stuff is the fancy alumina ceramic insulators, but even those can perform poorly if they are extra thick.
The CM300DY-24NF should be fine at 60khz provided you are operating at much less than 300A. No one can tell you the max switching speed of a transistor because its a function of other things (like current and temperature). Generally, the higher the operating frequency, the lower the allowed current.
Fri Sept 05 2014, 08:57PM
Steve Ward wrote ...
Kapton tape brought off ebay will work then? Im using a reel of the stuff i brought of Brocotts.
Thanks for the tip by the way ^^
hen918
Fri Sept 05 2014, 09:41PM
Kapton tape is a brilliant insulator however it was designed for withstanding high temperatures, not conducting heat well, so I didn't expect it to conduct heat well.
I'll try it!
Fri Oct 10 2014, 11:02PM
Should work, but it might be a good idea to remove the adhesive to lower thermal resistance more. A bit of thermal grease can also help by displacing air at the surfaces.
Fri Oct 17 2014, 05:57AM
First, I like the 0.001 inch thick kapton idea, can i get an estimate on the C per Watt rise on this idea?
Second, are there "traditional" epoxies to hold heat sinks on, and displace air? or should i stick with the silver epoxy types for this purpose?
