  • Guests: 46
Ian (37)
Lucas (40)
01/31 Mathias (42)
01/31 slash128v6 (53)
02/01 Barry (71)
x-Ray transformer series capacitor.
Sat Sept 06 2014, 08:45PM Print
Hey guys, im working on a driver for a large x-ray transformer.
Been messing about with it as a half-bridge to the point that i was getting 1 1/2 ft long white arcs from it. then i found an 80uF 1000VDC capacitor and put it in series, was getting arcs over 3ft....
Unfortunately i killed the capacitor. Thing is I need another one with higher peak currents.
Does anyone know where i can get such a capacitor?
Im running it at around 25kHz to 35kHz. I have tried normal Tesla coil capacitors but they don't seem to have enough capacitance to work properly. Does anyone know where i can find any large uF High voltage film capacitors with a high RMS Current. Im guessing figures like:
2000V @ 20uF @ 80Arms
Can anyone help me?
Thanks,
Thomas
GrantX
Mon Sept 08 2014, 04:30AM
That's a very impressive X-ray transformer, I can't believe it's capable of such high powers without melting! The only X-ray transformer I've played with was an old Gendex 50/60Hz unit capable of about 75kV peak. The HV windings would get quite warm after about 30 seconds at 10mA or so.
The only film capacitors I can think of are the big screw terminal filter caps like these: Link2 However they definitely aren't cheap and seem to be designed for high current DC filtering. Another alternative could be a whole bunch of the direct-mount IGBT snubber caps in parallel, but again they are fairly expensive.
Mon Sept 08 2014, 05:21AM
GrantX wrote ...
Thanks for the tip, now i know what to look out for. The transformer is rather insane, i actually got even more output recently... again this is only a half-bridge. I need to do some changes to the casing however before making it to a full-bridge. We had an incident yesterday.....
The wire terminals were getting very hot and the pressure relief valve for the oil was broken. I believe pressure got enough to push the hot metal connector though the plastic a little bit, one of the terminals then shorted to the case i think, causing an arc, then a huge amount of transformer oil-steam shot out around the connector. Was rather worried i had actually killed the transformer, but i did a continuity check and it seems ok, i may give it another try tonight.
-Thomas
EDIT:
using a clamp meter, i was actually measuring 350mA on the output....
Alex M
Mon Sept 08 2014, 11:29AM
amazed Very impressive Thomas!
I'm still bewildered at where you guys find these monster transformers, the best I've ever found is some 6kV standoffs still attached to an abandoned pole in a field.
As to your question I hate to be "that guy" but have you checked ebay? For example this might be suitable Link2 It is not cheap but I don't know where else you could source one.
Gotta love that series load resonant voltage rise action, if you tune it just right you can achieve zero current switching and greatly reduce MOSFET heating. You would need a Phase loop locked driver though such as this one to keep it in tune
1410174678 3943 FT165744 Redirect
Credit for this circuit goes to Link2
Wolfram
Mon Sept 08 2014, 12:54PM
Nice arcs. Does the X-ray transformer have a built-in divider to measure the output voltage? They often do.
I had a look on eBay UK and these Link2 are the best I could find. All 8 in parallel would give you 16µF at 1600V, at over 200A RMS. The auction accepts offers so it could be worth a try giving them a lower offer than the listed price.
If you have a shipping proxy in the US, three of these Link2 in series would be just about perfect.
Mon Sept 08 2014, 02:26PM
Thanks for the infomation guys, im just gonna consider what to do, wish i could the the ones from USA, but yeh, no shipping proxy saddly.
The XRT doesn't have a voltage divider it seems. Also, i am currently worrying about the XRT as i had an accident with it.
need to fix the power connector, i don't know if the transformer itself is ok, but resistance checks seem fine :)
Mon Sept 08 2014, 04:31PM
Well done! Very impressive results smile Please be careful though as "Transformer oil steam" is quite flammable. You don't want a mini version of this in your living room. Link2
I think Anders' Ebay UK link is probably your best bet. 8 of those in parallel will be a pretty heavy duty cap bank.
Mon Sept 08 2014, 04:51PM
Steve Conner wrote ...
Thanks for the tip, i placed an offer on them. If they don't do a nice enough price (im pretty skimp) then i might go to a capacitor manufacturer and ask if they have any similar of x'x in stock.
-Regards
Sun Sept 14 2014, 11:33PM
I think I can help you out here, Tom.
I have a case of 4μF 2.5 kV RMS 4kV pk knocking around somewhere - surplus to my Rayleigh line experiments.
They are film types, cylindrical about 2.5" high and 4" diameter with axial M8 terminations at either end. Their main use seems to be in high power snubbers, but they are also used in high power medium frequency RF circuits. (I never met anyone else who used them in a pulse forming line.)
They are still in current manufacture and so have data sheets. I'll try and find them in the next few days, and then I'll be able to find the data sheets.
I don't want any money for them, but the postage is likely to be about £20 for five of them to get your 20μF.
Mon Sept 15 2014, 06:30AM
Proud Mary wrote ...
PM Sent!
