  • Guests: 44
static electricity generator
Dédé!
Fri Jun 27 2014, 01:42PM Print
Dédé! Registered Member #4932 Joined: Thu May 17 2012, 01:42PM
When I was looking at youtube, I found this video https://www.youtube.com/watch?v=GGx83KppSCQ
I wanted to make the same thing, but a little more powerful, so I modified a simple stun gun schematic I found on the internet.
2v8scjo
I'll be using a modified flyback for the transformer.
Now I would like to know if the device is safe to use as it is in the schematic.
Here you can see the specs of this multiplier according to http://blazelabs.com/cw-brm-java.asp
Second i would like to know what turns ratio I should use. I was thinking about 6:2000 or something like that, but I don't know if the resonance or anything like that has a lot of influence on the output voltage of the transformer.
I also wonder if I have to insulate the components on the high voltage part of the schematic, because of the high voltage and if I have to, what insulation should I use?
Thanks in advance,
Dédé
dexter
Sat Jun 28 2014, 08:54AM
here is a good article on how to design a high frequency transformer Link2
5kHz is quite low frequency thus your transformer will require many turns - 8 for primary 0.3 Tesla max flux and ~2000 secondary for a 15mm diameter flyback core.
The coil will have some capacitance and it will resonate increasing the output voltage for the same number of turns so my sugestion is to wind some test secondaries and measure the output voltage.
50kV can jump 5cm on air or more based on the geometry of the plates/electrodes so insulating is a must unless space is not an issue
Dédé!
Sun Jun 29 2014, 10:57AM
Thx for your reply, I'll be looking into it.
Dédé!
Mon Jul 07 2014, 02:33PM
I have designed a PCB and component placement for the low voltage part of this schematic.
