  • Guests: 42
09/19 raff (48)
09/20 PYLEMET-mk2 (36)
09/21 Bill G (65)
SCR vs IGBT for capacitor bank switching
kimbomba
Tue Jun 10 2014, 06:32PM Print
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
I need to switch my cap bank for some exploding wire / coilgun applications. Would it be better to use SCR or IGBTs in terms of price? Thanks in advance
Tue Jun 10 2014, 06:42PM
I think SCRs will be more survivable when it comes to shorting caps.
Wed Jun 11 2014, 07:24PM
Yes, the SCR is a very robust part, it can take huge pulsed currents and energies (IGBT will desaturate and/or have a higher voltage drop).
Wed Jun 11 2014, 09:36PM
for exploding wire a mechanical switch may be best, or an scr.
for a coilgun I think igbt may be best as you can control the ON time
kimbomba
Wed Jun 11 2014, 11:15PM
Large SCRs are expensive, I've read here on the forum that they can be paralleled. Any suggestions/precautions in this situation? I assume equalizing resistors are unnecesary in this particular application is that correct?
Thu Jun 12 2014, 11:43AM
Paralelling SCRs would be a very difficult task, would probably require balancing inductors. With standard SCRs, the continuous current rating can be exceeded by much more than 10 times during a pulse, for short pulses maybe 50 times (only the pulsed energy dissipated in the chip is what matters), with IGBTs this is impossible, they desaturate at <10 times Icnom, the same as for DRSSTCs applies - exceed Icnom by ~4 times at most.
