  • Guests: 49
Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
12/10 davovinch (75)
Options for a fast amplifier array
rp181
Wed May 07 2014, 06:37PM Print
I trying to figure out the best way to design an array of amplifiers to drive some small piezoelectric actuators (unsure of capacitance yet).
Running through the numbers:
Max output voltage: 220V
Input voltage: 0-4.096V
Update rate: ~+/-0.5V step at 100khz (optimal)
Rise time target: 1-2us
Bandwidth (0.35/t_rise): 350khz
Max slew rate (2*pi*f*0.5v): ~4-8.17V/us
I was thinking of a two stage amplifier with gain equally split, so I could use a 36V rail for the preamp, yielding a gain of 7.4 for each stage. That means for the HV amplifier portion I'm looking at a GBW of ~1.3Mhz-2.6Mhz.
Now the best option I have right now is the PA84 (Link2
I'd rather not use these due to the cost, as well as the 5.5ma typ quiescent current and size.
The HV256 from supertex is nice- but unfortunately too slow.
Does anyone have any suggestions?
Dr. Slack
Wed May 07 2014, 09:25PM
OK, this doesn't have quite the voltage or speed, so it's a bit OT, but what a package of features Link2, definitely a solution in search of a problem!
