  • Guests: 51
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
Neutron scintillation detector.
Tue Apr 29 2014, 05:56AM Print
Just after a cursor search of facts, it appears with a normal scintillator plastic detector, gamma exclusion is the real problem.
link to previous thread: Link2
bismuth ? Link2
Is lead (or any high mass shielding) the only way to selectively exclude false (non-neutron) flashes?
If I put 1 cm of scintillating plastic, surrounded by 5 cm of lead I could exclude 90% of the gamma, and insignificant neutron quantity. But a 10cm diameter lead ball doesn't sound light in mass. In fact if I drop it from 300 feet up, I bet it could kill.
Is there any clever way to deal with this? Or are neutron detectors just kinda at this disadvantage in general?
EDIT: 5.8kg =12.7lbs, crap on a stick
NOTE TO SELF: look up lithium iodide in the morning.
dude_500
Wed May 07 2014, 03:10AM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
ZnS:Ag is a common neutron scintillator material that has very low gamma sensitivity. You generally wouldn't even need to worry about gamma shielding. The construction is often referred to as a Hornyak button. Bicron makes some of these neutron detectors.
In general though, he3 tubes are preferred for neutron detection. When biased properly you can easily discriminate non-neutron counts out simply because they have a much lower amplitude.
Wed May 07 2014, 04:07AM
dude_500 wrote ...
never heard this let me research this further! this is why i post here on 4hv.
Wed May 07 2014, 04:44AM
Should work. Also, one idea I came up with for shielding is layering bismuth and pyrolytic graphite but applying a transverse voltage, should work.
Wed May 07 2014, 05:11AM
Conundrum wrote ...
Please elaborate... are you using a e-field to disrupt the EM wave?!
Wed May 07 2014, 05:24PM
Possibly, there is a NASA paper from the late 1980's concerning superconductors being used as a radiation shield. It seems that the secret is to deflect the gammas and X-rays rather than absorb them, same sort of idea as a metamaterial I guess.
Wed May 07 2014, 06:50PM
What sort of nuclear industrial accident from small spill or leak to actual meltdown would need neutron detection to manage it?
The pocket dosimeters used throughout the nuclear industry worldwide detect gammas and energetic betas only.
My advice: don't waste your time on this neutron red herring.
Use a common miniature GM dosimetry tube like ZP1313, or if you want to go solid state, use a PIN photodiode like BPX65, which has been used in some miniature dosimeter designs since the 1980s.
The miniature GM tube has the advantage of low cost and simple circuitry which you can expect to work well right away. It also offers excellent immunity to destruction by intense ionizing radiation, where a PIN photodiode might suffer irreversible changes.
Sat May 10 2014, 01:11AM
Proud Mary wrote ...
So i was presuming in reactor related accidents the presence or absence of Neutron emission can be indicitive of how bad a reactor "event" is.
Is it a mere 3 mile island or the next Chernobyl...
Sat May 10 2014, 10:36AM
The problem here is that core damage will generate a similar number of neutrons as a melt-down, so without further information is just tells you things are bad or not.
Directed beams of gammas IMHO are a more accurate way to tell, as this suggests a full melt-down is imminent or in progress.
Sat May 10 2014, 11:38AM
If it was my problem, I would choose a PIN diode gamma ray spectrometer. The PIN diode array, its charge amplifiers, and telemetry modulator drivers would weigh very little. The Multichannel Analyzer (MCA) at the ground station would, with suitable software, directly identify the radionuclides responsible.
