  • Guests: 62
muller (38)
Dr. Mario (38)
Ben Solon (30)
01/28 LTX (57)
01/29 IAmSpock (18)
01/30 Ian (37)
Civilian Tri-copter For Environmental Research, ( Kickstarter, Phase 1).
1 2 3 4
Tue Apr 22 2014, 05:32AM Print
1398210777 2431 FT1630 Gen3
Gen 3 in flight.
Purpose :
To build, operate and prove flying robots can save people and serve humanity. By means of an open-source hack-friendly flying platform, to be used by private citizens (experts though, not just anybody) and nongovernmental groups, such as universities and journalists. All by a machine that doesn't bother to carry a weapon!
To accomplish this task, I'd like to follow and continue in the "XV-11 Neato lidar bounty contest" philosophy, using inexpensive but capable technology to build a low cost, easy to deploy machine in singles or fleets. The ultimate goal--relatively cheap, quick and predictable access to otherwise difficult and dangerous sites. In general, technology doesn't just advance, it accelerates. And in the case of micro-flying-robotics, democratization of this technology will be a significant part in how it evolves over these next decades.
Sites and events of interest:
Hanford, Windscale, Chernobyl, Fukushima, SL-1 Utah, MIC release Bhopal India, lovecanal NY, Oso Washington mudslide, Salton sea CA.
This thread is under construction for the next view days, so please bear with me.
The Kickstarter project hasn't been launched yet, but I'll give a link when I do....
I'm not wanting to solicit or beg users for backng here on 4hv, (though you are free to do so... cheesey) this thread is for the technical, fabrication and operational matters that are bound to pop up. ( its mostly instrumentation that worries me.) As a drone/UAV is only as useful as the payload / instruments it carries. Otherwise it's merely an expensive toy....
The machines:
There will be at least 3 machines built for phase 1.
Angel Strike 6, ( Gen 4, Ver 4, Mod 50, Type 2, Rev D. ) Serial: 04221401
Angel Strike 7, ( Gen 4, Ver 4, Mod 50, Type 2, Rev D. ) Serial: XXXXXXX
Angel Strike 8, ( Gen 4, Ver 4, Mod 60, Type 2, Rev D. ) Serial: XXXXXXX
The Mod 60 machine differs in that it carries my most advanced "sense and avoid" sensor suite. based on LiDAR and an optical flow system.
links :
Link2 Ducted Academic Tricopter (Asymmetric, 3rd Generation)
Link2 Academic Bicopter Using Castle ESC's [ It Flies! ]
Link2 Recieving GPS In High Radiation Fields... (Among Other Unfavorable Situations.)
Link2 IARC, Autonomous flight competition.
Link2 Bhopal disaster
Link2 Chernobyl disaster
Link2 Fukushima Daiichi nuclear disaster
Features:
-Flies for 6 to 8 minutes on LiPo batteries (at 2.2kg) [already proven by flights. Feb, 2014.]
-Has 9 degree of freedom inertial measurement unit. (mag, baro, acc, gyro)
-Ducts and similar features to improve human safety.
-XV-11 LiDAR
-ultra sound and IR altitude feedback / awareness.
-Two optical flow cameras. (one looking down, the other on a gimbal)
-Flight controller = MultiWii Crius PRO in tricopter mode.
-Forward Counter rotating APC 10x5.5 MR's props.
-Two Castle Phoenix ICE 50's for front fans.
-Single Turnigy AE 30A ESC for the tail.
-RCtimer BC-2836,1120 KsubV tail motor, 7 turns.
-Two RC Timer BC-3530, 1400 KsubV motor, 10 turn.
-Tail fan uses a cut-down 9x6 APC (cut to 5.8x6)
-Tail servo = HiTec HS-225 MG.
-60% of the lift is from the forward fans, 40% or less is from the tail fan.
-Affirmative kill switch (for human safety) and LiPo saver. (separate from the arm switch), (does not use AI)
-GPS capable, but still operates in GPS denied environments.
-Abort while avoiding obstacles and return home, at one switch throw. (Uses AI onboard)
-Water proofing, for continuous flight in heavy rain.
-Experimental radiation shielding, Gamma, X ray, Alpha, Neutron. (Probably with Boron, as Pb is too heavy)
Specs / metrics:
-2.2 kg all-up-weight.
-3s2p LiPo (paralleled 3.3Ah, nanotech turnigy's, 511 grams. 6.6Ah total.)
-Props are 10" and 6" in diameter.
-Length 37", duct span 31", height 7".
-Structure = polystyrene, fiber glass, carbon fiber, Balsa and Bass wood, Epoxy.
-LiPo for now, but backwards compatible with my soon to come Fuel cells.
1398401279 2431 FT1630 Top1
1398401279 2431 FT1630 Top2
1398401279 2431 FT1630 Top3
Tue Apr 22 2014, 07:59AM
If you want to raise funds from environmentalists
I suggest that you change the name to something 'friendlier' than xxxx STRIKE.
The word 'strike' has military/combat connotations.
for a small license fee you can use one of my suggestions cheesey
1) enviro-copter
2) enviro-watch
3) enviro-search
4) enviro-mate
5) enviro-heli
6) enviro-guard
7) enviroplatform
8) enviro1
9) enviro2
etc.
Shrad
Tue Apr 22 2014, 09:26AM
make it from compressed straw held by corn starch, and call it the permacopter :D
Dr. Slack
Tue Apr 22 2014, 11:31AM
As a drone/UAV is only as useful as the payload / instruments it carries. Otherwise it's an expensive toy....
Great copter. I would imagine that fewer, larger props than the traditional quad gives better efficiency through less induced drag and larger motors for the same craft weight. However, it's a long way from there to a product.
Are you contemplating a complete drone+instrument system, an airframe that will take any instrument, or something in between? Why should people give you money, what is your expertise that they are buying into? Will you sell to end-users who want a turnkey system, or system integrators, who will buy your airframe if it has advantages over the other lifting chassises they can buy off the peg. If a turnkey system, proprietory interfaces that you might hope would lock people into your system, or perhaps it would lock other instruments out? Or open interfaces that would allow system integrators to use your airframe with almost anything, but replace it at the drop of a hat if a new offering in the market had better duration/payload etc?
I'm not having a go, I'm just saying think very carefully about what will attract people to your end product, and don't spread yourself too thin by developing too much new stuff
Tue Apr 22 2014, 05:08PM
I need pics of the Fukushima tank farms, but I don't know about copyright and such matters. I don't want to steal others work, is citing the source enough?
Wed Apr 23 2014, 01:54AM
Dr. Slack wrote ...
Great copter. I would imagine that fewer, larger props than the traditional quad gives better efficiency through less induced drag and larger motors for the same craft weight. However, it's a long way from there to a ...
Yes. I'm not wanting, like many others, to put 4, 6, 8, 10 or 12 motors/props/ESCs on an arm and wire harness, just to drag it all through the sky. Motors improve with volume of copper and steel, but parasitic losses build quickly with absurdly large numbers of added on junk.
Thu Apr 24 2014, 12:52AM
Okay I've finalized the math, it does look like I can use PEM Fuel cells, I'll post more details soon, but so far 6-8 minutes of flight is the sticking point with lipo batteries. But if I can pin down for a quote this company, I might have a 3kg machine flying for 45 to 75 minutes at a time.
This beats all the tiny expensive (60k $) quads that are less capable than my (2k $) tricopter.
Fuel Cell = 1150g @ 500W, 15V. (specs not right yet)
hydrogen tankage = 400 g
BC3530 motor, 435W, 10T (3 of these)
current Gen 3 mass without batteries = 1300g
so all-up-weight = 1150 + 400 + 1300 = 2850 grams (math not right yet)
EDIT: nope, i just double checked, need the 1kW fuel cell - ugh! dead
(1.7kg mass instead of 1.15kg)
AndrewM
Thu Apr 24 2014, 07:59PM
nvm.
Thu Apr 24 2014, 10:09PM
Update to first post.
New info posted.
Sat Apr 26 2014, 07:19PM
article related to Fukushima Neutron and critcality possibilities. Link2
im also thinking in terms of the rewards kickstarter requires, not sure what people would value though at the 20 to 50 US $ marks though
less than 20$,
less than 50$
less than 100$
300$ or more...
500$ or more...
1000$ or more...
im still thinkng though.....
im pondering high quality poster pics of northern California locations 300 feet up, like Shasta dam and lake, or Sacramento river.
