  • Guests: 47
muller (38)
Dr. Mario (38)
Ben Solon (30)
01/28 LTX (57)
01/29 IAmSpock (18)
01/30 Ian (37)
How to Diffuse LED Light as in a Laptop Screen
Sun Nov 09 2014, 04:00AM Print
I need lights for my drones and other projects, but I cant figure out how the light is so uniformly dispersed. is it just white plastic? ive googled some terms but not found anything useful. I just don't see examples as thin as laptop screens.
Sun Nov 09 2014, 06:04AM
Try googling LCD backlight diffuser, or just take apart any broken flat display.
Here is a take-apart story in another forum. Link2
Sun Nov 09 2014, 06:40AM
the great wiki : Link2
Diffusers
For a non-ELP backlight to produce even lighting, which is critical for displays, the light is first passed through a lightguide - a specially-designed layer of plastic that diffuses the light through a series of unevenly-spaced bumps. The density of bumps increases further away from the light source according to a diffusion equation. The diffused light then travels to either side of the diffuser; the front faces the actual LCD panel, the back has a reflector to guide otherwise wasted light back toward the LCD panel. The reflector is sometimes made of aluminum foil, a simple white-pigmented surface, or, as in the 3M Vikuiti ESR, hundreds of polymer layers alternating between a low and high refractive index. Between the lightguide and the LCD panel is usually placed a reflective polarizer film which vastly increases efficiency by repeatedly reflecting any unpolarized light back, which would otherwise be absorbed by the LCD's rear polarizer.
I guess using white doped epoxy will show bright spots...
Shrad
Sun Nov 09 2014, 04:24PM
I guess sanded perspex with a side facet facing LEDs and other facets but the front one with reflective material would already provide enough diffusion for nice indication lights
Sun Nov 09 2014, 04:40PM
Never understood why LCD screens don't just use RGB WS2812 diodes behind the panel to optimize efficiency.
This would be a lot cheaper than OLED and the individual strips could be user replaceable when they wear out.
hen918
Sun Nov 09 2014, 05:52PM
Conundrum wrote ...
You would get bright spots that would need some sorting out
Tue Nov 11 2014, 09:26AM
Non linear optics?
ConKbot of Doom
Sat Nov 15 2014, 08:44PM
The plastic to spread it as you'd expect, dots instead of being completely frosted. then some wierd, films/optics on top of it.
Once I get free time IVe been planning on scouring craigslist for an LED TV to strip the polarizer and LCD from and use as an overhead workbench light.
